Old 09-26-2013, 02:12 AM
Steve088 Steve088 is offline
Default Re: How to get Mixer window to float?
Is this actually a thing? Floating windows must be one of the most simplest things to code. Has anyone found a solution for this for PT11, Windows 7 / 8?
Old 09-26-2013, 05:37 AM
sunburst79 sunburst79 is offline
Nope. Avid will have to recode this sometime.
I'm used to it and stretch my main window over both monitors then use Alt+Tab to cycle through applications.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 09-28-2013, 07:26 PM
I could deal with having to stretch the main window across my two monitors, if they were both the same size. I have 15' laptop with two 24' monitors either side. I Have a bit of trouble adjusting it, and I have to do it every time I boot up pro tools because the settings don't save. Yet another thing to add to the 'Pro Tools is lame' list.
Old 09-28-2013, 08:59 PM
Have you tried closing PT using the Alt+F4 command? That should cause PT to open with the same settings as you closed it.
Scott
Core 2 Specs Page
Old 09-29-2013, 07:13 AM
Bill Denton Bill Denton is offline
Quite frankly it was a major screw-up for Avid to not take care of this as part of the PT 11 rewrite, assuming it could be done.
However, it is possible that in order to implement some other features, Avid simply could not code for the floating windows on the Windows platform...
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
  #16
Old 09-29-2013, 10:27 AM
From what I understand this feature was added around v5. Earlier versions of PT on Windows didnt have this behavior. Or so I've been told. I think the first version of PT on Windows something like 4.2.x.
I'm suprised they didn't do something in PT 7-8 which is around the time they started messsing with code underlying the GUI. But that was fairly invasive and there where some serious bugs to fix.
But yeah it's kind of overdue. Maybe they are saving that for PT 12 along with bins.
Scott
Core 2 Specs Page
  #17
Old 09-29-2013, 10:18 PM
cwsand's Avatar
cwsand cwsand is offline
Which is why I have 2 identical monitors. Would be a nice feature though. I have a similar problem using a MacBook Pro and a different sized monitor, but most of my work is done on pc. Not a show stopper by any means.
Chris
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
  #18
Old 10-25-2013, 03:45 PM
Chris
Yeah, identical size monitors is generally an optimal setup too, and I have that setup with my desktop, but I work a lot on my Tohsiba, as it's quieter and uses less power.
This has still got me scratching a hole in my head. How, at this stage of development, is the feature of floating windows STILL yet to be implemented. This isn't some fancy, pointless feature, and I would've thought it'd be high up on AVIDs 'to code' list. They must of dug it into a hole with a lot of quick fixes,,,,
I'd like to agree with Bill Denton, in that the implementation of new INCREDIBLE features like Oflline Bouncing (OMFG!), formed impenetrable barriers of cryptic binary around the possibility of floating windows. Can only hope that it comes with PT12 and upgrades from 11 are cheap.
  #19
Old 05-31-2014, 05:04 PM
2crows 2crows is offline
thanks, works for me
  #20
Old 04-11-2019, 05:30 PM
AMZavareei AMZavareei is offline
5 year BUMP!
black mixer-window. Meatbaker Windows 2 03-17-2014 12:35 PM
Any way to float the help window on "top"? gopher Getting Started 1 12-13-2013 03:56 AM
Float window. please tell me..... rucontent 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-26-2009 04:44 AM
Sends Mixer Window? guilt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-26-2008 01:42 PM
Event List as float window ? jeff caldwell71 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-14-2003 11:50 PM
