converting from 48K with PT
Is there a way to convert from 48K to 44.1K betwen the source and PT or inside PT but before recording, I´m using apogge and 888(24).
thanks |
Re: converting from 48K with PT
Hello!
You can convert in PT from 48 to 44.1 using "bounce to disk"command. |
my favorite sample rate converter would work for what you're trying to do: go analog into PT. aside from that, I don't think there's a way to do the conversion BEFORE recording, as bounce to disk will only work AFTER recording and even then it's not real time.
There are several realtime SR-convertors (hardware). A very good, but expensive one is the BitBox. If you do this a lot, it's worth the investment....
------------------ Arno Peeters www.tapetv.nl |
tank you very much for uour time.
Converting to MP3 | keytone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 02-24-2009 05:54 PM |
mp3 converting HELP?!?! | steve.05251 | Pro Tools M-Powered (Win) | 0 | 01-28-2009 03:58 PM |
Converting from pc to mac! i need some help | mr razor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-16-2008 02:09 AM |
Converting 24 bit to 16 | mblack | Pro Tools TDM Systems (Mac) | 14 | 04-02-2005 05:55 PM |
converting a WMA to a WAV ? | Pop-cycle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-13-2004 05:52 PM |
