Old 03-01-2004, 01:48 PM
jborrmann jborrmann is offline
Default Sync I/O - LTC Distance?
I am helping on a permanent install and I need to know how far SMPTE (LTC) can travel? What is my maximum cable length? Is it cable dependant?
Thank you.
Jason Borrmann
Old 03-01-2004, 06:21 PM
timcissell timcissell is offline
Default Re: Sync I/O - LTC Distance?
I think SMPTE signals should behave just like any other audio signal as far as how far you can run it down a wire. (Pretty dang far.)
I would recommend that at the end of the cable run and before you use the SMPTE to drive anything that the SMPTE code should be reshaped by anything that will regen the code. Just to get those waves squared off again...
If you're trying to run the SMPTE code signal down the wire and NOT reshape it, that seems like it might be the source of a problem. You might want to check with the Post Production Pros on the DUC main index... Good luck!
Old 03-03-2004, 09:54 AM
west audio west audio is offline
pushing 120' with no problems
Glen West
OT - how do you distance yourself? Stig Eliassen General Discussion 19 10-27-2010 03:43 AM
USB distance DannyG Pro Tools TDM Systems (Mac) 6 06-14-2009 10:45 AM
Out there, in the distance... cinetj Post - Surround - Video 6 07-28-2008 08:45 AM
Max distance PT - Mac? diegogat Pro Tools TDM Systems (Mac) 1 05-28-2003 11:26 AM
Long Distance Sync I/O Question... 1150Post Post - Surround - Video 11 01-30-2003 01:27 PM
