  #41
Old 10-20-2019, 08:33 AM
Jordan_J Jordan_J is offline
Default Re: Pro Tools 2019.6 (Win 10) starts itself?
Any development on this one?
  #42
Old 10-20-2019, 11:14 AM
philgrab philgrab is offline
It's not Ozone 9, although I too had installed it recently. I can fire up Protools, launch no projects and exit. It still comes back up a 2nd time. Conundrum for sure.
  #43
Old 10-20-2019, 01:31 PM
ChuckS ChuckS is offline
This happens here also. In the event viewer, the crash references ucrtbase.dll which is a Windows Visual C++ runtime file. So basically any plug/module/etc written in C++ could be causing the crash. Another side issue of this is that it creates crash dumps every time you exit PT so there could be gigabytes of dumps accumulating if you don't use a cleaner app. Check here for files: C:\Users\~yourusername\AppData\Local\CrashDumps
Thing is that even if you don't get the restart issue, PT is still crashing on quit and creating crash dumps on exit. Anyone any good at reading those may be able to isolate the issue.
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
  #44
Old 10-21-2019, 02:36 PM
taylor4814 taylor4814 is offline
Default PT Restarts after Exiting, Endless Loop...?
Win 10
PT 2019.6
What is causing this? PT restarts after exiting, endless loop...?
  #45
Old 10-21-2019, 02:39 PM
amagras amagras is offline
Default Re: PT Restarts after Exiting, Endless Loop...?
Exactly the same here, at first I thought it was Skootch but it isnt, I almost sure it started happening after the last Windows 10 update
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
  #46
If I End Task from Windows Task Manager, that seems to stop it... but how to fix?
  #47
Old 10-21-2019, 04:15 PM
I think so too..
Windows 10 Home
Version: 1903
Build: 18362.418
  #48
Old 10-21-2019, 04:18 PM
This has been pretty well resolved back to the Ilok driver. It has been advised to roll back.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
  #49
jjnssn jjnssn is offline
Happening on my windows system as well. If I open a blank session it seems not to happen so I am guessing it may be a plug-in however haven’t been annoyed enough yet to figure it out.
  #50
Old 10-21-2019, 04:27 PM
It is the ilok driver. Advised to roll it back and hopefully they will address it soon.
pro-tools-pc.com
Intel I7 9900k
Win 10
12.7 .0.676 Install Update Prompt Endless Loop AVIDIVA Pro Tools 12 2 12-22-2016 01:26 AM
Activating my PT9 to PT10-PT11 upgrade is an endless loop? mike_mccue Windows 1 06-23-2013 03:45 PM
Core audio - sound stuck in endless loop lpbaker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-23-2010 08:03 AM
Bounce to Disk creates endless loop boneboy Pro Tools TDM Systems (Mac) 2 08-13-2006 08:05 PM
Need Help with endless loop Mark Manela Pro Tools TDM Systems (Mac) 1 05-28-2002 04:27 PM
