#21
Re: Too much latency with HDN at 44.1
And I do not see that you have actually posted any details on the CPU errors you are getting. What exact DAE errors? Check all the installed plugins are up to date (not just the ones you are trying to use). You can also confirm you can track at low latency with no plugins instantiated at all, and then if you cannot then uninstall all third party plugins, and try again. Also try a new totally empty session (not from template) if that does not work. |
#22
Oh well, try to get 32 sample buffers running with no plugins in the monitoring path at all and see waht you get, etc. tryign all I mentioned above. You absolutely have to optimize everything. No Blutooth, no WiFi, no wireless keyboard or mouse, not A/V software, no Spotlight indexing (turn it off on *all* drives for now). etc. etc. And just like with NCPU=7, leave all of these done no matter how annoying etc. while you counting other tuning/testing. Once you've found the best possible performance point yo can try backing off these things. |
#23
This thread also seems to lack any information about your disk setup, exact make/model/rpm of drives, how they are attached if external and where audio/session files and any samples are stored. And are you using HD timeline cache? Actually a really clear description in one post of your whole system, Mac Pro model/date code. CPU specs and speed, memory, etc. and exact DAE errors you are getting would be great.
#24
Thank you for the advice. This is seeming like a lot of potentially fruitless efforts for downgrading to HDN.
I'll try some to see if I can get it stable at 32 long enough to see whether I can deal with the latency. |
#25
I've tried with and without timeline cache.
System: Mac Pro 5,1 (I think) Dual Quad 2.66 16GB RAM OS 10.8.3 PTHD 10.3.7, 11.0.2 HD3 Accel PCIx in Magma connected via PCIe HD Native Core I run no VI's. Dedicated audio drives are WD Caviar Black. I've also tried the sessions from my SSD. |
#26
Is there any chance you can just live with LLM on the HDN setup? |
#27
Not with any real projects, but for overdubs I have enough outboard everything.
#28
FWIW I suggest -
Use PT11 No Waves plugins (take Waveshell out of PI folder and put in unused one) Hyperthreading (HT) = Off Only Avid plug ins Buffer = 32 See if that is a working starting place. ----------- This is my opinion but -- for low buffer work I have found speed trumps cores. Although your MP is an awesome machine its base clock frequency is not that high. I spent a long time trying to make a 2.6GHz i7 Mac mini do this work and it could not. When I switched to the 3.5GHz i7, huge difference. -------- Note: the total difference in performance under the most demanding tasks you could do with HT on or off will be about 20%. Depending on the tasks that difference is often closer to zero. Don't let the marketing of HT fool you - it doesn't double your CPU just allows it to use any potential idle time a core has.
2017 27" iMac 3.8GHz i5, 1TB SSD Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB Musician: http://www.ivanlee.net/ Design Engineer: http://www.propowerinc.com/resume.html |
#29
None of the computer issues would explain the latency though. If the computer was not powerful enough to run at a low buffer, he would just get stops and error messages, but the latency would not be increased. It either works or it doesn't.
I'm wondering if something else could be causing the delay, perhaps a plugin on the master buss? I can definitely say this is not normal, but I can't explain why some people have trouble on their systems and others do not. I know Propower has had some difficulties also. On the other hand, I've been using a 64 buffer since my dual core Imac and 003 days, and always sounded like real time to me. Now with HD Native and my 5.1 Quad 2.8, it's even better. |
#30
WRT his perception of latency - can't it be that 44.1/64 may be too much for him? It is 2X the latency he is used to from TDM land?
Automation latency when using plugins that have long latency | pyrodave | Pro Tools 11 | 2 | 01-27-2014 11:22 AM |
omni/native latency vs mbox pro latency | chrisdee | Pro Tools HDX & HD Native Systems (Win) | 34 | 03-30-2012 07:24 AM |
Latency Issues - changing latency has no effect | Kippa-Dee | Pro Tools M-Powered (Win) | 1 | 07-15-2010 08:39 PM |
Piano VI's- Latency Latency!! | MARVINBASS | Virtual Instruments | 5 | 04-27-2006 01:09 AM |
Unity DS-1 and Latency... Anyone else feel the latency makes the Plugin unusable? | Mt.Everest | Pro Tools TDM Systems (Mac) | 7 | 08-26-2001 04:53 PM |
