#1471
Re: Firewire HD w/ E-machines 6811 or Gateway 7426GX?
Is anyone using a 002R, and recording to an external firewire drive with either of these two machines (e-machines 6811 or Gateway 7426GX)? If so, what are your DaveC results and H/W buffer settings? Is there a way to add a second internal drive(maybe removable)to either of these laptops? I'm very close to purchasing one of these machines or building the Allenstein Machine and getting a large LCD HD TV w/ DVI i/o and great resolution.
Thanks for your help! Eric
EAR |
#1472
Re: 6811 dual boot?
Is it possible to run two separate versions of XP on the same machine?
Maybe that's too far but I can't afford two computers and still need to run graphics/web/internet apps as well as PT. I know that installing anything but PT makes for a sad PT operator so I was wondering if I could separate them. Maybe this is achievable via different users but I'm assuming not to the level I'd like. I actually have an extra copy of XP if that's what it would take. Are other 6811 users running web and other apps on thier machine without PT problems? Which apps? I'd mostly need to run design+web apps. Thanks for any words. Will
http://soundofthatday.com |
#1473
Re: 6811 dual boot?
I7-4930K, X79-Deluxe, 2133 32 GB, GT640, 512GB 860 Pro, 1TB Evo, WDB 2TB X2, Win 10 Pro, PT Ultimate 2020.12 Studio One 5 Pro, REAPER 6 RME, Daking, Heritage, ISA, Sytek |
#1474
Re: 6811 dual boot?
thanks, Will
#1475
Re: 6811 dual boot?
damn, older versions of partition magic are dirt cheap on ebay. anything wrong with getting version 6 or 7?
thanks, will
#1476
Re: Best Laptops for PTLE
OK ...
after a number of reinstalls & trying different options i'm about ready to give up! it is my wife's laptop ... i was just hoping to 'borrow' it from time to time did a fresh install as ACPI ... couldn't get pro tools to play or record a single track. used device manager to change to standard pc ... pro tools worked but would only do 16 tracks on the DAVEC, so .... reinstalled as standard pc and tried again ... DAVEC was about the same, 24 tracks peaks the cpu meter, 20 was ok but running produces a 9073 error (disk too slow)! this is all to the internal drive ... when i use my firewire drive i got 19 tracks (with plugs) but can run 32 tracks in record (no plugs) no problem. also had problem trying to change to memory usage = system cache .... everytime i change it xp won't boot and i get a message saying 'windows is unable to load the locally stored profile' or something to that extent ... have to boot in safe mode & change it back to be able to get into xp! i've posted my sandra thingy below for anyone who wants to offer a suggestion before i turn the machine back over to the missus permenantly! i also did a CPU Arithmetic Benchmark and it seems the cpu is seriously underperforming (see below) might just have to wait until there's another dell machine that is fully approved and works outa the box like the 8600 stew M-box 6.4 cs9 SiSoftware Sandra Processor Model : AMD Athlon(tm) 64 Processor 3000+ Speed : 800MHz Model Number : 3000 (estimated) Performance Rating : PR1200 (estimated) Type : Standard L2 On-board Cache : 1MB ECC Synchronous, Write-Back, 16-way set, 64 byte line size Mainboard Bus(es) : ISA AGP PCI IMB PCMCIA CardBus USB FireWire/1394 i2c/SMBus MP Support : No MP APIC : Yes System BIOS : Insyde Software O1.06 System : MiTAC Mainboard : MiTAC Total Memory : 1GB DDR-SDRAM Chipset 1 Model : Mitac Apollo K8T800 CPU to PCI Bridge Front Side Bus Speed : 2x 800MHz (1600MHz data rate) Chipset 2 Model : Advanced Micro Devices (AMD) Athlon 64 / Opteron HyperTransport Technology Configuration Front Side Bus Speed : 2x 800MHz (1600MHz data rate) Total Memory : 1GB DDR-SDRAM Memory Bus Speed : 2x 160MHz (320MHz data rate) Video System Monitor/Panel : Default Monitor Monitor/Panel : Default Monitor Monitor/Panel : Default Monitor Adapter : MOBILITY RADEON 9600 Physical Storage Devices Hard Disk : FUJITSU MHT2060AT (56GB) Hard Disk : Oxford Semiconductor Ltd. OXFORD IDE Device LUN 0 IEEE 1394 SBP2 Device CD-ROM/DVD : QSI CDRW/DVD SBW242B (CD 24X Rd, 24X Wr) (DVD 3X Rd) Logical Storage Devices Hard Disk (C:) : 56GB (54GB, 96% Free Space) (NTFS) CD-ROM/DVD (D:) : N/A Sounds (E:) : 93GB (31GB, 33% Free Space) (NTFS) Stuff (F:) : 93GB (26GB, 28% Free Space) (NTFS) Peripherals Serial/Parallel Port(s) : 0 COM / 1 LPT USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : VIA USB Enhanced Host Controller USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub FireWire/1394 Controller/Hub : VIA OHCI Compliant IEEE 1394 Host Controller PCMCIA/CardBus Controller : Generic CardBus Controller Infrared Device : IrDA Fast Infrared Port Keyboard : PC/AT Enhanced PS/2 Keyboard (101/102-Key) Mouse : Microsoft PS/2 Mouse Communication Device(s) Device : Smart Link 56K Voice Modem Power Management AC Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP/2002 Home (Win32 x86) 5.01.2600 (Service Pack 2) Network Services Network Drivers Enabled : No Performance Tips Warning 100 : Large memory sizes should be made of Registered/Buffered memory. Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. ****************************************** SiSoftware Sandra CPU Arithmetic Benchmark (these results posted lower than an AMD Athlon 1.2GHz 256L2!!!) Benchmark Results Dhrystone ALU : 3688 MIPS Whetstone FPU : 1268 MFLOPS Whetstone iSSE2 : 1629 MFLOPS Results Interpretation : Higher index values are better. Performance Test Status Run ID : STEW-000ADD0116 on Sunday, 26 June 2005 at 5:42:30 PM NUMA Support : No SMP Test : No Total Test Threads : 1 Multi-Core Test : No SMT Test : No Dynamic MP/MT Load Balance : No Processor Affinity : PP0 Number of Runs : 64000 / 640 Processor Model : AMD Athlon(tm) 64 Processor 3000+ Speed : 800MHz Model Number : 3000 (estimated) Performance Rating : PR1200 (estimated) Type : Standard L2 On-board Cache : 1MB ECC Synchronous, Write-Back, 16-way set, 64 byte line size Chipset 1 Model : Mitac Apollo K8T800 CPU to PCI Bridge Front Side Bus Speed : 2x 800MHz (1600MHz data rate) Chipset 2 Model : Advanced Micro Devices (AMD) Athlon 64 / Opteron HyperTransport Technology Configuration Front Side Bus Speed : 2x 800MHz (1600MHz data rate) Features SSE2 Technology : Yes SSE3 Technology : No HTT - Hyper-Threading Technology : No |
#1477
Hi there,
I'm upgrading my laptop for use with my 002 rack and wanted to see if anyone had insight or experience with this machine... Gateway M680MX pentium M 750 (1.86GHz) 915 PM chipset 1024 MB 533 MHz DDR2 SDRAM 60 GB 7200rpm ultra ata HD I notice that all the online deals for gateways use the intel even though the athlon 64s are available in the gateway stores (none of which are nearby). is it all just a price difference or are the athlons doing better with the PT systems? thanks, Chairman Blow |
#1478
Here is the info on my M6805,
002R 6.4 CS9 SiSoftware Sandra Processor Model : Mobile AMD Athlon(tm) 64 Processor 3000+ Speed : 1.80GHz Model Number : 3000 (estimated) Performance Rating : PR2706 (estimated) Type : Mobile L2 On-board Cache : 1MB ECC Synchronous, Write-Back, 16-way set, 64 byte line size Mainboard Bus(es) : ISA AGP PCI IMB CardBus USB FireWire/1394 i2c/SMBus MP Support : 1 CPU(s) MP APIC : Yes System BIOS : AT/AT COMPATIBLE Total Memory : 1.2GB DDR-SDRAM Chipset 1 Model : VIA Technologies Inc Apollo K8T800 CPU to PCI Bridge Front Side Bus Speed : 2x 800MHz (1600MHz data rate) Chipset 2 Model : Advanced Micro Devices (AMD) Athlon 64 / Opteron HyperTransport Technology Configuration Front Side Bus Speed : 2x 800MHz (1600MHz data rate) Total Memory : 1.3GB DDR-SDRAM Memory Bus Speed : 2x 164MHz (328MHz data rate) Video System Monitor/Panel : Default Monitor Monitor/Panel : Default Monitor Monitor/Panel : Default Monitor Adapter : ATI MOBILITY RADEON 9600 Series Physical Storage Devices Hard Disk : HTS726060M9AT00 (56GB) Hard Disk : NEWMOTION TECHNOLOGY CORP. 2035A-00 IEEE 1394 SBP2 Device CD-ROM/DVD : Slimtype COMBO LSC-24082K (CD 24X Rd, 24X Wr) (DVD 3X Rd) Logical Storage Devices Home (C:) : 36GB (27GB, 75% Free Space) (NTFS) CD-ROM/DVD (D:) : N/A Bootmagic (E:) : 47MB (33MB, 71% Free Space) (FAT) Komodo (R:) : 112GB (78GB, 69% Free Space) (NTFS) Peripherals Serial/Parallel Port(s) : 1 COM / 0 LPT USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : Standard Enhanced PCI to USB Host Controller USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub FireWire/1394 Controller/Hub : VIA OHCI Compliant IEEE 1394 Host Controller PCMCIA/CardBus Controller : Generic CardBus Controller Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard Mouse : Synaptics PS/2 Port Pointing Device Mouse : HID-compliant mouse Human Interface : USB Human Interface Device MultiMedia Device(s) Device : Realtek AC'97 Audio for VIA (R) Audio Controller Communication Device(s) Device : Smart Link 56K Modem Printers and Faxes Model : hp psc 2100 series Power Management AC Line Status : On-Line Battery No 1 : 90% Operating System(s) Windows System : Microsoft Windows XP/2002 Home (Win32 x86) 5.01.2600 (Service Pack 1) Network Services Adapter : VIA Rhine II Fast Ethernet Adapter Adapter : Broadcom 54g MaxPerformance 802.11g Performance Tips Warning 100 : Large memory sizes should be made of Registered/Buffered memory. Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. The first thing I noticed is that your processor speed is only 800mhz. For an AMD 64 3000 it should be 1.8Ghz. It looks like you are running on battery but it says AC is online? The default CPU speed on battery for most e-machine/gateway 64's is right around 800mhz, on AC power it goes back to normal. I'd check your power options in Control Panel and make sure you are set to "Always On" and if you have the "AMD Power Now" tab set it to high performance. You may want to check in your BIOS to see if there is a speed/performance facility there as well...? Your performance is where it probably should be for 800mhz. Other than that and the fact that your board is a Mitec Apollo K8T800 and the M6805 is a VIA Apollo K8T800 there is virtually no difference. I am running XP Service Pack 1. My internal HD is a Hitachi 7200. I have a WD 7200 8MB cache in my FW enclosure. Allen can you help here, or anyone else that knows more than me...?
#1479
Re: 6811 dual boot?
I got mine here, Partition Magic 8 Fair price and quick shipment.
#1480
Re: 6811 dual boot?
big preesh wkg.
Will
USB support with Pro Tools 9 Laptops | moldenke | Pro Tools 9 | 4 | 11-18-2010 04:46 PM |
Dell Laptops and Pro Tools | sgladm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 05-03-2006 10:32 AM |
Best laptops for Pro tools | felixflank | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 04-07-2006 06:41 AM |
alien laptops and pro tools | geefive | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-29-2006 10:17 AM |
Pro Tools and Apple laptops | Jsalam112 | Pro Tools TDM Systems (Mac) | 1 | 04-08-2002 09:28 AM |
