Old 07-30-2016, 06:21 AM
KeyplayerG's Avatar
KeyplayerG KeyplayerG is offline
Default Multiple Units Question
I've got an MC Control that I've been using a couple of years. I added the Transport about a month or so ago. I am considering adding a couple of Mix units, but I had some questions before I buy.
1) How do the features on the mix work when working with the Control? For example: The control has 8 knobs to control 8 functions. Once a function, say insert is selected, the 8 knobs now show the plugs, once selected, the 8 knobs now show the settings of the plug. Since the 8X5 matrix of the Mix does the exact same thing, I would like to know what changes when it is now in "Slave Mode." Do the 8 mix knobs become page 2 of options because the Control becomes page 1 as default?
2) Is that banking issue resolved? If I have 2 Mix units, will I be able to bank in groups of 20 faders?
3) Can I lock any of the MIx units, for example, assign one to be the permanent 8 bus or VCA section?
4) Once I have a Mix, can Fader Flip Mode be extended to the Control unit?
Finally, as all the attention is being diverted to the S3/Dock now, is it worth bothering to buy the Mix if it along with any other Artis Series device is about to lose any remaining support? Or wil they have ample support for another cycle, say 5 years?
Thanks in advance for any replies.
My Rigg:
Nuendo 1 - 7 |VST Studio Connect Pro | Windows 10 Pro | Intel i7 - 5820K CPU @ 3.30 | 64-bit OS | 32GB of RAM |RME HDSPe RayDAT | NVIDIA GeForce GTX 750 Ti Video Card | Euphonix MC Control & Transport | Xkeys | UAD-2 Octo Core with UAD-1 Legacy Ultra Pak | Isotope RX4 | Melodyne 3.2 | Voxengo Plugins | Real Guitar | B4 II | EZ Drummer | Drumagog 4 | Virtual Guitarist 2 | Korg, Roland, Kurzweil Synths | Apogee Big Ben | 32 Channel Panasonic DA-7 desk | Equator D5 (5.1) & Mackie 824 (St.) monitors | VS-1680 & 880 HDR's |
Old 07-30-2016, 07:59 AM
Manu101 Manu101 is offline
Default Re: Multiple Units Question
To my knowledge, the banking issue is still not resolved. I think if you have a control unit, this whole setup (mix and control) will bank in steps of 4
The mix units are not discontinued... so I think they are good for a while.
Manu
PT Ultimate - Win10 - i7 7800X - RME Fireface UFX II - 2x Avid S1, 1x Dock with an iPad 7th gen - Genelec 8330 5.1 system
Old 07-30-2016, 12:15 PM
KeyplayerG's Avatar
Wow, you can't even bank in blocks of 8? That's ridiculous! You should AT LEASTbe able to bank in a block of the 8 fader unit(S).
This guy seems to have solved the banking problem and he's on Studio One. He's got 3 Artist Mix & 1 MC Control (28 Faders) and he seemsto be banking (via HUI Protocol at that) 8 faders minimum through all of his units. I THOUGHT he might be banking 28 faders at a time. But, if not, it looks as though he's moving each unit at least 8 faders. Look at the 11:17 min. through 16:42min. section of the video to see what I mean.
https://www.youtube.com/watch?v=b00PF4Y8X9A
Old 08-02-2016, 03:44 PM
MoPro's Avatar
MoPro MoPro is offline
This guy seems to have solved the banking problem and he's on Studio One. He's got 3 Artist Mix & 1 MC Control (28 Faders) and he seemsto be banking (via HUI Protocol at that) 8 faders minimum through all of his units. I THOUGHT he might be banking 28 faders at a time. But, if not, it looks as though he's moving each unit at least 6 faders. Look at the 11:17 min. through 16:42min. section of the video to see what I mean.
Yes you can bank in groups of 8 tracks if you have a Control, and a Mix!
But I must say that I have reverted back to EuControl ver. 3.3.1, from 3.4, because AVID chose to change the way the "Faders Off" command is initiated!
The only way we get it back is if Steinberg adds the "Faders Off" command to their EuCon Adapter... and who knows when that will happen... if ever!
At least Cubase still works with a version of EuControl that still has the "Faders Off" command hard wired to the Shift + Solo buttons on Ch.1.
But, I expect the next Cubase update will require the latest version of EuControl, and if they do not implement the "Faders Off" command... we will be stuck with what another user (Led) describes as what sounds like an "Ice Skating Rink" during mixing!
Al
Computer Asus P9X79 Deluxe | Intel i7 3930k | 32 Gig Ram | Intel 520 SSD's | 2T Caviar Black
Software Win 7 Ultimate (64bit) | Cubase Pro 9.5.41 (64bit) | WaveLab 9.5.25 (64bit) | HALion 6 (64bit)
Hardware RME FireFace's UFX / 800 | MOTU MTP AV USB | Avid Artist Series: Control, Mix, and Transport | EuControl ver. 18.3
Old 08-05-2016, 05:07 AM
Originally Posted by MoPro View Post
Yes you can bank in groups of 8 tracks if you have a Control, and a Mix! Al
Is that when you make the 2 units bank independently?
Also, as I have 2 mix units, can I make them bank in steps of 16?
Thanks
Manu
Old 08-05-2016, 07:12 AM
KeyplayerG's Avatar
Thanks
No, you can only bank in groups of 8 faders. Look at the video I posted.
Multiple Artist Control units on the same network? tonepad Artist Series 2 10-01-2014 11:23 PM
Clocking multiple units for dummies -- Help please sounds_good 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 03-22-2011 10:23 AM
what ethernet switch are you using for multiple MC units on a Mac snake doc Artist Series 5 07-07-2010 02:57 PM
Question about old 888 units... superpenguin79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-28-2005 09:31 AM
multiple 001 units tracker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-29-1999 08:42 PM
