Old 03-16-2014, 06:54 PM
Loudyman's Avatar
Loudyman Loudyman is offline
Default Finally, switch or router for multiples artist units ? (and which one to get ?)
So, what is better to use with those units, a switch or a router ?
My protools system/Mac isn't connected to the internet, do I need a router though ?
And which model to get ?
I've found this one so far:http://www.amazon.com/NETGEAR-ProSAF...=netgear+fs108
My other concern is that nearly every modern switch/routers have now a "green ethernet" feature : http://en.wikipedia.org/wiki/Energy-Efficient_Ethernet,
and I don't know if some connection issues will occur with this technology and the artist series ?
Any thoughts ?
Thanks,
Ludo.
Mac Pro 8 cores Intel Xeon harpertown 3Ghz (Early 2008)| ATI radeon HD 2600 XT | 16GB RAM | 750GB system drive + 3x1TB drives |
MAC OSX 10.6.8 | Protools HD 10.3.2 |
HD3 PCIe Accel |
192 I/O |
Old 03-16-2014, 07:32 PM
robertg robertg is offline
Default Re: Finally, switch or router for multiples artist units ? (and which one to get ?)
Originally Posted by Loudyman View Post
Any thoughts ?
Thanks,
Ludo.
you only need a switch. the one you linked is fine
Old 03-16-2014, 08:13 PM
Loudyman's Avatar
Thanks robertg,
With this one: Netgear FS108 : "8 ports 10/100 auto speed-sensing UTP", can I use STP or other ethernet cables with it or only UTP ones ?
Once I have plugged everything, is there something special to configure on the mac or the surfaces ?
I've read something with DHCP and static IP address somewhere on the DUC.
Sorry, I'm not a network expert
HD3 PCIe Accel |
192 I/O |
Old 03-16-2014, 08:53 PM
Thanks robertg,
i don't think it matters, you aren't pushing much data and I doubt you are operating near areas of huge EM interference, standard cables are fine
Old 03-25-2014, 05:22 PM
Loudyman's Avatar
Alright, thanks !, but I'm still hesitant to buy a system with 2 mix+ Control+ transport.....
So far, two problems bother me:
-It seems that there's a problem with the power supply of these units (?)
and
-Connections issues with Eucon are widely common and updates for Mac are now limited to osx 10.8 / 10.9.
But I'm still on osx 10.6 and I can't really update my whole TDM system, which is stable, past 10.7 because of compatibility issues
between Mac osx/ TDM cards and Harpertown Mac.
Will I have to stay at Eucon 2.7.x forever ?
Ludo.
HD3 PCIe Accel |
192 I/O |
Anyone using Artist Mix units with Windows? albee1952 Artist Series 13 12-18-2012 11:55 PM
Router/Switch conflicts / Ip address problems Xill Artist Series 10 08-10-2011 06:44 PM
what ethernet switch are you using for multiple MC units on a Mac snake doc Artist Series 5 07-07-2010 02:57 PM
> IT HAS FINALLY HAPPENED! I need to switch... megahurt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 09-02-2005 10:15 AM
Sticky Faders after router switch..... s0nguy ICON & C|24 1 10-16-2004 07:19 AM
