Old 03-16-2012, 10:29 PM
Sidecut Sidecut is offline
Default Stop Play Error
I had a crash on a win 7 64 bit system with Mbox 3 Pro that required a reinstall of all software. I decided to use the opportunity to use my upgrade to 10 from 9. I installed PT 10 successfully and performed the Win 7 Optimizations as outlined in the AVID KB. Opened session and ran it. All Good.
I then wanted to install the PTIEP. Per another KB article, I decided to install my PTIEP and then update via the provided links. I elected to only install Velvet and then Velvet patch as a test. I opened a sesh with the velevet plug, it was present but I could no longer play the session and got the "play stop" bug. I also got an error message saying Hardware was in use by something else. I quit, restarted, tried different sessions without any Velvet instances and still got the "Play Stop" but not longer got the in use message.
Any help would be appreciated
Music won't play. Play button flashes and Stop button lights up Mattitude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 24 04-16-2020 03:03 PM
Notation view edit while in play cause play to stop working. soybalm Pro Tools 10 1 04-18-2013 11:11 AM
The old "Stop and Play button" error Trainwrecker Pro Tools 10 9 03-24-2012 09:53 PM
When press play the stop key lite and play key blinking Sam Yin Tips & Tricks 6 12-05-2009 08:26 PM
Stop & play mixerboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-05-2003 03:26 PM
