Closed Thread
  #961
Old 03-31-2007, 05:48 PM
eatblueshell eatblueshell is offline
Default Re: Problems with PTLE? Post your configuration here..
Hello all, I am desperate here, I can't get the damn thing to work. I have the Mbox One and pro-tools LE 6.7
When I try and install the Mbox and pro-tools, and then launch protools, I get a bluescreen that says windows has been closed to prevent damage to your system yada yada,
and for some reason, during the installation it would not be able to find the device drivers. so I went out and downloaded the appropriate drivers, and then tried again, this time it installed fine, but when I tried to open it I got these Messages:
ProToolsLE.exe - Entry Point Not Found
The procedure entry point _DsiSetThreadPriority@8 could not be located in the dynamic link library DSI.dll
Error Starting Program
A reuqired DLL file, DFW.dll was not found.
What is causing this, and how do I fix it.
Here is a brief rundown of my PC:
Dell Inspiron e1505 with Intel Core 2 Duo 1.83 ghz
2 gb of DDR Dual Channel Ram
80 gb Sata Hard drive
Radeon x1300 128mb Mobile Graphics Card.
What's the deal?
  #962
Old 04-01-2007, 12:08 PM
october october is offline
My issue:
I recently updated from 6.9 to 7.3.1cs2 on launch it either freezes, stop responding or crashes "a fatal error has occurred pro tools must exit." and im also getting this "C++ runtime error this application has requested the Runtime to terminate in a unusual way. Please contact the application´s support team for more information".
SiSoftware Sandra
System
Manufacturer : System manufacturer
Model : System Product Name
Version : System Version
Serial Number : System Serial Number
System Chassis
Manufacturer : Chassis Manufacture
Type : Desktop
Can be locked : Yes
Version : Chassis Version
Serial Number : Chassis Serial Number
Asset Tag : Asset-1234567890
Boot-up State : Safe
Power State : Safe
Thermal State : Safe
Security State : External Interface Locked-out
Mainboard
Manufacturer : ASUSTeK Computer INC.
MP Support : 1 Processor(s)
MPS Version : 1.40
Model : P5LD2-Deluxe
Version : Rev 1.xx
Serial Number : MB-1234567890
System BIOS : 64-0312-000010-00101111-061405-945P
On-board Devices
Onboard Ethernet : Ethernet Adapter (Enabled)
System Memory Controller
Error Correction Capability : None
Number of Memory Slots : 4
Maximum Installable Memory : 4GB
Chipset 1
Model : ASUSTeK Computer Inc 82945P Processor to I/O Controller
Bus(es) : ISA PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Front Side Bus Speed : 4x 201MHz (804MHz data rate)
Maximum FSB Speed / Max Memory Speed : 4x 267MHz / 4x 167MHz
Width : 64-bit
Multi Video Card Support : Crossfire Technology
IO Queue Depth : 12 request(s)
Chipset 1 Hub Interface
Type : DMI (Direct Media Interface)
Version : 1.00
Number of Ports : 4
In/Out Width : 4-bit / 4-bit
Multiplier : 3/1x
Speed : 1x 100MHz (100MHz data rate)
Logical/Chipset 1 Memory Banks
Bank 0 : 512MB DDR2-SDRAM 4.0-4-4-12 (tCL-tRCD-tRP-tRAS) CR1
Bank 4 : 512MB DDR2-SDRAM 4.0-4-4-12 (tCL-tRCD-tRP-tRAS) CR1
Bank 6 : 512MB DDR2-SDRAM 4.0-4-4-12 (tCL-tRCD-tRP-tRAS) CR1
Bank 7 : 512MB DDR2-SDRAM 4.0-4-4-12 (tCL-tRCD-tRP-tRAS) CR1
Channels : 2
Speed : 4x 134MHz (536MHz data rate)
Multiplier : 8/12x
Width : 64-bit
Memory Controller in Processor : No
Refresh Rate : 7.80µs
Power Save Mode : No
Fixed Hole Present : No
APIC 1
Version : 2.00
Multiplier : 1/2x
Maximum Interrupts : 24
IRQ Handler Engaged : Yes
Enhanced Support : Yes
Memory Module 1
Manufacturer : Samsung
Model : M3 78T6553CZ3-CD5
Serial Number : F20280E3
Type : 512MB DIMM DDR2-SDRAM
Technology : 8x(64Mx8)
Speed : PC2-4300U
Standard Timings : 4.0-4-4-11 (tCL-tRCD-tRP-tRAS)
Version : 1.2
Date of Manufacture : 26. november 2005
Set Timing @ 267MHz : 5.0-4-4-11 (tCL-tRCD-tRP-tRAS)
Set Timing @ 267MHz : 4.0-4-4-11 (tCL-tRCD-tRP-tRAS)
Set Timing @ 200MHz : 3.0-3-3-8 (tCL-tRCD-tRP-tRAS)
Memory Module 2
Serial Number : F20580E6
Speed : PC2-4300U
Version : 1.2
Memory Module 3
Type : 1GB DIMM DDR2-SDRAM
Technology : 16x(64Mx8)
Speed : PC2-5300U
Standard Timings : 5.0-5-5-15 (tCL-tRCD-tRP-tRAS)
Version : 1.2
Date of Manufacture : 25. december 1999
Set Timing @ 333MHz : 5.0-5-5-15 (tCL-tRCD-tRP-tRAS)
Set Timing @ 267MHz : 4.0-4-4-12 (tCL-tRCD-tRP-tRAS)
Set Timing @ 200MHz : 3.0-3-3-9 (tCL-tRCD-tRP-tRAS)
Environment Monitor 1
Model : Winbond W83627(T)HF ISA
Version : 10.01
Mainboard Specific Support : No
Temperature Sensor(s)
Board Temperature : 29.0°C / 84.2°F
CPU Temperature : 54.0°C / 129.2°F td
Power / Aux Temperature : 66.0°C / 150.8°F
Cooling Device(s)
Auto Fan Speed Control : No
CPU Fan Speed : 1389rpm
Voltage Sensor(s)
CPU Voltage : 2.74V
Aux Voltage : 3.78V
+3.3V Voltage : 3.36V
+5V Voltage : 5.64V
+12V Voltage : 12.89V
-12V Voltage : 2.12V
-5V Voltage : 2.69V
Standby Voltage : 5.07V
Battery Voltage : 3.07V
PCI Bus(es) on Hub 1
Version : 2.30
Number of Bridges : 8
PCI Bus 0 : PCI (1/1x PCIClk)
PCI Bus 1 : PCI (1/1x PCIClk)
PCI Bus 2 : PCIe (3/1x PCIClk)
PCI Bus 3 : PCIe (3/1x PCIClk)
PCI Bus 4 : PCIe (3/1x PCIClk)
PCI Bus 5 : PCIe (3/1x PCIClk)
PCI Bus 6 : PCIe (3/1x PCIClk)
PCI Bus 7 : PCIe (3/1x PCIClk)
PCI Bus 8 : PCIe (3/1x PCIClk)
Number of PCIe Lanes : 23
LPC Hub Controller 1
Model : ASUSTeK Computer Inc 82801GB/GR (ICH7 Family) LPC Interface Controller
ACPI Power Management Enabled : Yes
Advanced TCO Mode Support : Yes
Advanced TCO Mode Enabled : No
High Precision Timer Support : Yes
High Precision Timer Enabled : No
Delayed Transaction Enabled : Yes
LPC Hub Controller 2
Model : ASUSTeK Computer Inc 82801G (ICH7 Family) SMBus Controller
USB Controller 1
Model : ASUSTeK Computer Inc 82801G (ICH7 Family) USB Universal Host Controller
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
Supported Speed(s) : Low (1.5Mbps) Full (12Mbps)
Legacy Emulation Enabled : No
USB Controller 2
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 3
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 4
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 5
Model : ASUSTeK Computer Inc 82801G (ICH7 Family) USB 2.0 Enhanced Host Controller
Version : 2.00
Specification : 1.00
Interface : EHCI
Channels : 8
Companion Controllers : 4
Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) High (480Mbps)
Addressing Support : 64-bit
FireWire/1394 Controller 1
Model : ASUSTeK Computer Inc TSB43AB22 1394a-2000 OHCI PHY/Link-Layer Controller
Version : 1.10
Interface : OHCI
Speed : 400MHz
System SMBus Controller 1
Model : Intel 801xx/63xx SMBus
Version : 0.01
Specification : 2.00
Advanced TCO Mode Enabled : Yes
Slave Device Enabled : Yes
PEC Support : Yes
Speed : 100kHz
Expansion Slot(s)
PCIEX16 : PCI-X 32-bit +3.3V Shared PME Half-Length Used
PCI_1 (5h) : PCI 32-bit +3.3V Shared PME Half-Length Available
PCI_2 (6h) : PCI 32-bit +3.3V Shared PME Half-Length Available
PCI_3 (7h) : PCI 32-bit +3.3V Shared PME Half-Length Available
PCIEX1_1 (3h) : PCI-X 32-bit +3.3V Shared PME Half-Length Available
PCIEX16_2 (4h) : PCI-X 32-bit +3.3V Shared PME Half-Length Available
Port Connector(s)
PS/2 Keyboard : Keyboard / PS/2
USB1 : USB / USB
USB2 : USB / USB
USB3 : USB / USB
USB4 : USB / USB
LPT 1 : Parallel Port ECP/EPP / DB-25 pin female
MIDI : MIDI / DB-15 pin male
Audio Line Out1 : Audio / Mini-jack
Audio Line Out2 : Audio / Mini-jack
Audio Line Out3 : Audio / Mini-jack
Audio Line Out4 : Audio / Mini-jack
Audio Line Out5 : Audio / Mini-jack
Audio Line Out6 : Audio / Mini-jack
SPDIF_OUT1 : Audio
SPDIF_OUT2 : Audio
FireWire 1 : FireWire/1394
Silicon_Image_SATA1 : ATA
GbE LAN 1 : Network / RJ-45
USB5 : USB / USB
USB6 : USB / USB
USB7 : USB / USB
USB8 : USB / USB
ITE_IDE1 : ATA
ITE_IDE2 : ATA
SB_IDE : ATA
SB_SATA1 : ATA
SB_SATA2 : ATA
SB_SATA3 : ATA
SB_SATA4 : ATA
Silicon_Image_SATA2 : ATA
CD : Audio / CD-ROM Sound Input
FP_AUDIO : Audio
COM 1 : Serial Port 16550A / DB-9 pin male
Joy Stick : Joystick / DB-15 pin male
FLOPPY : Floppy Disk
CHA_FAN : None
CPU_FAN : None
PWR_FAN : None
CHA_FAN2 : None
FireWire 2 : FireWire/1394 / FireWire/1394
Performance Tips
Notice 224 : SMBIOS/DMI information may be inaccurate.
Warning 2508 : All memory slots are full. Upgrading the memory may be difficult or expensive.
Warning 2518 : Mainboard temperature is too high.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
  #963
Old 04-02-2007, 04:58 AM
chrisf chrisf is offline
I have a new ASUS P5B-E system based on the P965 chipset with an Intel Core 2 Duo processor (E6600), 2GB of DDR2-800 RAM, along with the onboard VIA IEEE 1394 firewire interface.
It has serious problems with playback (filtered dream demo):
H/W Buffer Size Error
1024 samples -9129
512 samples or lower -9092
If I enable "Ignore Errors During Playback/Record" I occasionally hear a short burst (< half a second) but that's it. I always get error -9092 when attempting to record (input 1).
- I tried setting the processor affinity hack - no change.
- The multi-core Windows hotfix had no change, with or without the registry change.
- I've tried disabling the Gigabit ethernet interface in Windows and BIOS - no change.
- The DirectX diag tool (dxdiag) doesn't output audio with the "Music" test or the
"DirectSound" test, when the output is set to "Digidesign MBox 2 Pro 1/2". (The DirectSound test works fine for the SoundMAX HD Audio output - on motherboard.)
I did some searches on the DUC forum before buying this motherboard, for which there were no complaints, so I'm at a total loss of what to do from here :-( Any suggestions would be most appreciated!
Protools info:
PTLE 7.3.1cs2
MBox 2 Pro factory
Windows/software info:
Windows XP Hotfix 896256 applied
iLok driver upgraded to 5.5.0.2618
DirectX upgraded to 9.0c
Extra Info on IEEE 1394 interface:
< FireWire/1394 Controller ` >
Model: ASUSTeK Computer Inc VT6306 VIA Fire II IEEE-
1394 OHCI Link Layer Controller
Version: 1.00
Interface: OHCI
Enhanced Support: No
Speed: 400MHz
SiSoftware Sandra
System
Host Name : PROTOOLS
User : Chris
Workgroup : MSHOME
Processor
Model : Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz
Speed : 2.40GHz
Performance Rating : PR8166 (estimated)
Cores per Processor : 2 Unit(s)
Threads per Core : 1 Unit(s)
Type : Dual-Core
Internal Data Cache : 2x 32kB Synchronous, Write-Thru, 8-way set, 64 byte line size
L2 On-board Cache : 1x 4MB ECC Synchronous, ATC, 16-way set, 64 byte line size, 2 threads sharing
Mainboard
MP APIC : Yes
System BIOS : American Megatrends Inc. 8.12
System : System manufacturer System Product Name
Mainboard : ASUSTeK Computer INC. P5B-E
Total Memory : 2GB DDR2-SDRAM
Chipset 1
Model : ASUSTeK Computer Inc P965/G965 Memory Controller Hub
Front Side Bus Speed : 4x 267MHz (1068MHz data rate)
Memory Bus Speed : 4x 200MHz (800MHz data rate)
Video System
Monitor/Panel : LG L204WT(Analog)
Adapter : NVIDIA GeForce 7600 GT
Physical Storage Devices
Hard Disk : WDC WD3200AAKS-00SBA0 (298GB)
CD-ROM/DVD : LITE-ON DVDRW LH-18A1P (CD 48X Rd, 48X Wr) (DVD 6X Rd, 6X Wr)
Logical Storage Devices
Hard Disk (C:) : 298GB (291GB, 98% Free Space) (NTFS)
audio (D:) : 298GB (298GB, 100% Free Space) (NTFS)
CD-ROM/DVD (E:) : N/A
Peripherals
Serial/Parallel Port(s) : 1 COM / 1 LPT
USB Controller/Hub : Intel(R) ICH8 Family USB Universal Host Controller - 2830
USB Controller/Hub : Intel(R) ICH8 Family USB Universal Host Controller - 2831
USB Controller/Hub : Intel(R) ICH8 Family USB Universal Host Controller - 2832
USB Controller/Hub : Intel(R) ICH8 Family USB Universal Host Controller - 2834
USB Controller/Hub : Intel(R) ICH8 Family USB Universal Host Controller - 2835
USB Controller/Hub : Intel(R) ICH8 Family USB2 Enhanced Host Controller - 2836
USB Controller/Hub : Intel(R) ICH8 Family USB2 Enhanced Host Controller - 283A
USB Controller/Hub : USB Root Hub
FireWire/1394 Controller/Hub : VIA OHCI Compliant IEEE 1394 Host Controller
Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
Mouse : Microsoft PS/2 Mouse
Power Management
AC Line Status : On-Line
Operating System(s)
Windows System : Microsoft Windows XP/2002 Home 5.01.2600 (Service Pack 2)
Network Services
Adapter : Attansic L1 Gigabit Ethernet 10/100/1000Base-T Adapter
  #964
Old 04-02-2007, 09:01 AM
Khatru Khatru is offline
Hi chrisf,
I imagine you checked this out since it looks as if you've done some research. I saw this though when I did a search for your "-9129 error" in "suport and downloads". Check it out if you havent already:
This is directly from that, and there's more, including the affinity issue that you've already tried.
-9093, -9094, -9129 error messages occuring on Windows operating systems.
For Intel-based systems, updating the Intel Ultra ATA storage controller to the Standard Dual PCI IDE controller resolves these errors. To do this:
1. Go to Start Menu > Control Panel > System > Hardware > Device Manager > IDE/ATA ATAPI Controllers.
2. Right Click on the Intel Ultra ATA storage controller and choose Properties.
3. Click the Driver tab, and then the Update Driver button.
4. The driver update wizard will start. Choose the bottom option for "Specify the location of the driver" and click "Next".
5. Now choose the bottom option for "Display a list of all drivers in a specific location" and click "Next".
6. Double click on the Standard Dual PCI IDE Controller to install this driver.
7. Close the device manager and restart the computer.
8. If the operating system is Win98 or WinME, be sure to enable DMA for any Hard Drives after the restart (see abase #6381).
Good Luck, Dave
~Intel Core 2 Duo E6600
~Asus P5W DH Deluxe
~Xion Supernova 600W
~2 X 1GB CORSAIR PC2 6400
~WD 80 & 250 GB Hard Drives
~GeForce 7600GT
~XP2 SP2
~Mbox
Intel Core 2 Duo E6600/Asus P5W DH Deluxe/Nexus NX-5000/2 X 1GB CORSAIR PC2 6400/WD 80 & 250 GB Hard Drives/GeForce 7600GT/Lite-On CDRW/AcoustiCase 360/2-120mm AcoustiFans/XP Pro SP2/Mbox LE 7.3.1
  #965
Old 04-03-2007, 04:40 AM
I got my PTLE/MBox2 Pro setup working at last
The fix was using a PCI firewire card instead of the onboard VIA one; so the ASUS P5B-E works but not its onboard firewire.
I managed to get hold of this card which seems to work great so far:
NEC PCI uPD72873 IEEE1394 Adaptor
The box is marked ST Lab - PCI Firewire 1394 Controller Card as pictured at:
http://www.cancomputer.com/index.php?sku=2069
  #966
Old 04-05-2007, 02:36 PM
DJ Decryption DJ Decryption is offline
Greetings friends,
Spkguitar - you are master when it comes to these issues... it seems like you've probably solved over 400 people's problems. I've tried to fix this issue on my own (using a lot of your recommendations from other posts), but I'm at an impasse. I was about to bite the bullet and purchase a new computer, but I thought I'd give it one last try and see if you could see where potential conflicts would be arising. Anyone else who has thoughts, feel free to offer them!
Here's the scenario: I'm running a Lenovo Thinkpad Z60m (Sandra specs below) with the Mbox Mini and PTLE 7.1. Everything worked great for about 3 weeks, and suddenly I started receiving the -9092, -9093, -9094 interrupt errors anywhere from 1-5 minutes into a session during record and playback. I hadn't installed anything new or changed any settings that would have caused this problem. It occurs with the same frequency whether I use my external firewire drive or my internal system drive. I tried disabling all the recommended things (bluetooth, wireless, APCI battery control etc.), running in diagnostic mode, switching to standard IDE controllers, reinstalling PTLE several times... no luck. I'm stumped because many of the other Thinkpad models are compatible, and I can't find any components in this thing that aren't up to Digi specs. The chipset is fine. It's just weird that it was working for 3 weeks and then start having interrupt problems. I thought it might be the external HD (Western Digital seems to have caused problems for a couple of people), but the same thing happens with the same predictability when I record to the system drive. I appreciate any help you can offer - you're my last resort before I have to drop another couple grand on a new laptop. Thank you!
SiSoftware Sandra
Processor
Model : Intel(R) Pentium(R) M processor 2.13GHz
Speed : 2.13GHz
Performance Rating : PR2873 (estimated)
Cores per Processor : 1 Unit(s)
Type : Mobile
Internal Data Cache : 32kB Synchronous, Write-Back, 8-way set, 64 byte line size
L2 On-board Cache : 2MB ECC Synchronous, ATC, 8-way set, 64 byte line size, 2 lines per sector
Mainboard
Bus(es) : PCI PCIe IMB PCMCIA CardBus USB FireWire/1394 i2c/SMBus
MP Support : No
MP APIC : Yes
System BIOS : IBM 77ET54WW (1.14 )
System : IBM 2529RCU
Mainboard : IBM 2529RCU
Total Memory : 1023MB DDR2-SDRAM
Chipset 1
Model : IBM 82915PM/GM/GMS, 82910GML Host Bridge
Front Side Bus Speed : 4x 133MHz (532MHz data rate)
Total Memory : 1GB DDR2-SDRAM
Memory Bus Speed : 4x 133MHz (532MHz data rate)
Video System
Monitor/Panel : Default Monitor
Monitor/Panel : ThinkPad MaxBright Display 1280x800
Monitor/Panel : Generic Television
Adapter : ATI MOBILITY RADEON X600
Hard Disk : HTS721010G9SA00 (93GB)
Hard Disk : WD External HDD Device IEEE 1394 SBP2 Device
Hard Disk : IC25N080 ATMR04-0 USB Device
CD-ROM/DVD : HL-DT-ST DVDRAM GMA-4082N (CD 24X Rd, 24X Wr) (DVD 3X Rd, 3X Wr)
IBM_PRELOAD (C:) : 89GB (67GB, 76% Free Space) (NTFS)
Audio CD (D:) : 0 byte(s) (CDFS)
My Book (E:) : 298GB (176GB, 59% Free Space) (FAT32)
R51 (F:) : 75GB (5.4GB, 7% Free Space) (NTFS)
Peripherals
Serial/Parallel Port(s) : 1 COM / 0 LPT
USB Controller/Hub : Intel(R) 82801FB/FBM USB Universal Host Controller - 2658
USB Controller/Hub : Intel(R) 82801FB/FBM USB Universal Host Controller - 2659
USB Controller/Hub : Intel(R) 82801FB/FBM USB Universal Host Controller - 265A
USB Controller/Hub : Intel(R) 82801FB/FBM USB Universal Host Controller - 265B
USB Controller/Hub : Intel(R) 82801FB/FBM USB2 Enhanced Host Controller - 265C
USB Controller/Hub : USB Mass Storage Device
USB Controller/Hub : USB Composite Device
USB Controller/Hub : Digidesign Mbox 2 Firmware Updater
FireWire/1394 Controller/Hub : OHCI Compliant IEEE 1394 Host Controller
PCMCIA/CardBus Controller : Ricoh R/RL/5C476(II) or Compatible CardBus Controller
Infrared Device : IBM ThinkPad Fast Infrared Port
Mouse : ThinkPad UltraNav Pointing Device
Communication Device(s)
Device : ThinkPad Modem
Printers and Faxes
Model : Microsoft Office Document Image Writer
Model : Canon MP170 Series Printer
Power Management
Operating System(s)
Windows System : Microsoft Windows XP/2002 Professional 5.01.2600 (Service Pack 2)
Network Services
Adapter : Broadcom NetXtreme Gigabit Ethernet
Performance Tips
Notice 5901 : CD 1x= 150kB/s; Exercise caution when comparing measured versus published ratings.
Notice 5902 : DVD 1x= 11.08Mbps Exercise caution when comparing measured versus published ratings.
  #967
Old 04-05-2007, 02:51 PM
Ozmo Ozmo is offline
I am using the Mbox2. After having problems on my Dell XPS laptop and a firewire drive, I upgraded to a Tyan Quad. I still get buffer errors. I would love to try a different peice of hardware to rule out the Mbox2 but I am not about to upgrade to the 003 without some assurance that this won't happen with that hardware too.
[/b]Error: The operating system held off interrupts for too long. If this occurs often, try increasing the "H/W Buffer Size in the Playback Engine Dialog. (-9094)[/b]
Occurs: Can happen in any session but most often occurs during record and playback of sessions with more than 2 or 3 midi tracks or sessions with lots of automation. I am currently running PT 7.1cs10. I don't use any plug-ins that did not come with the ignition pack other than a full version of BFD and a full version of Melodyne Uno. I have separate 10,000 rpm Raptor SATA drives for Windows, Audio, and BFD.
I have reverted back to an Acronis image of a fresh windows install after all tweaks whenever I try a fresh install of Pro-tools. I have tried upgrade to 7.3 but I get massive buffer errors on sessions with only a single audio track after the upgrade to 7.3. (Which I have attempted twice.) Upgrading to 7.3 makes it worse. Going back to 7.1cs10 brings it from unbearable to only very frustrating levels.
I believe I have gone above and beyond in troubleshooting this problem. Unfortunately my Mbox2 is past the free support period.
Steps I have taken:
BIOS tweaks:
Integrated Devices > Audio Codec: [Disabled]
Advanced > NV RAID Configuration > [Disabled]
Advanced > PCI Configuration > Onboard Device Control > IEEE1394 control > [Enabled]
Advanced > Floppy Configuration > Legacy Diskette A: [Disabled]
Advanced > Floppy Configuration > Legacy Diskette B: [Disabled]
Advanced > I/O Device Configuration > Serial port A: [Disabled]
Advanced > I/O Device Configuration > Serial port B: [Disabled]
Advanced > I/O Device Configuration > Parallel port: [Disabled]
Advanced > I/O Device Configuration > Floppy disk controller: [Disabled]
Advanced > IntruderSupport [Disabled]
Boot > QuickBoot Mode: [Enabled]
Boot > POST errors: [Enabled]
Power > AMD PowerNow [Disabled]
Windows Tweaks:
Disabled system standby and power management
Disabled ClearType font smoothing
Disabled Data Executive Prevention
Enabled DMA for IDE hard drives
Disabled Network Adapter drivers
Disabled system startup items and services
Deleted DAE and Pro-Tools preference files and Digidesign Databases folders. (I have written a batch file to accomplish this annoying task.)
Adjusted display settings for best performance
Set Processor Scheduling to background services and memory usage to system cache
Set display color quality to 16-bit, and hardware acceleration to none
Disabled desktop backgorund image
Disabled screen saver
Disabled Fast User Switching
Disabled Power Schemes and Hibernation/Sleep modes
Disabled System Sounds
Disabled System Restore
Disabled Automatic Updates
Disabled Automatically Restart in Start Up & Recovery
Disabled Error Reporting
Disabled Remote Assistance
Disabled Offline Files
Disabled Remote Desktop
Disabled Internet Synchronize Time
Disabled Hide Inactive Icons
Disabled Automatic Desktop Cleanup Wizard
Disabled NTFS Last Access Time Logging
Disabled Notification Area Balloon Tips
Disabled CDROM Autoplay
Disabled Disc Indexing
SiSoftware Sandra Report:
System
Host Name : QUADZILLA
User : Ozmo
Workgroup : WORKGROUP
Processor
Model : 2x Dual Core AMD Opteron(tm) Processor 265
Speed : 1.81GHz
Model Number : 2912 (estimated)
Performance Rating : PR13016 (estimated)
Type : Dual-Core
Internal Data Cache : 64kB Synchronous, Write-Back, 2-way set, 64 byte line size
L2 On-board Cache : 1MB ECC Synchronous, Write-Back, 16-way set, 64 byte line size
Mainboard
Bus(es) : PCI PCIe USB FireWire/1394 i2c/SMBus
MP Support : 2 Processor(s)
MP APIC : No
System BIOS : Phoenix Technologies Ltd. 2003Q2
System : TYAN Computer Corp S2877
Mainboard : TYAN Computer Corp S2877
Total Memory : 2.7GB ECC DDR-SDRAM Registered (Actually 4GB of this Registered ECC DDR-SDRAM)
The Tyan Quad motherboards (S2877 and the newer S2927) both use nVidia chipsets, not AMD.
Chipset 1
Model : Advanced Micro Devices (AMD) Athlon 64 / Opteron HyperTransport Technology Configuration
Front Side Bus Speed : 2x 1005MHz (2010MHz data rate)
Total Memory : 2GB ECC DDR-SDRAM Registered
Memory Bus Speed : 2x 200MHz (400MHz data rate)
Chipset 2
Video System
Monitor/Panel : Plug and Play Monitor
Adapter : NVIDIA GeForce 6600
Physical Storage Devices 10,000rpm SATA Raptor drives
Hard Disk : WDC WD1500ADFD-00NLR1 (69GB)
Hard Disk : WDC WD360ADFD-00NLR1 (69GB)
Hard Disk : WDC WD740ADFD-00NLR1 (69GB)
CD-ROM/DVD : LITE-ON DVDRW SHW-160P6S (CD 48X Rd, 48X Wr) (DVD 6X Rd, 6X Wr)
Hard Disk (C:) : 26GB (18GB, 70% Free Space) (NTFS)
Storage (E:) : 43GB (26GB, 59% Free Space) (NTFS)
BFD (G:) : 34GB (25GB, 73% Free Space) (NTFS)
Audio (F:) : 140GB (135GB, 97% Free Space) (NTFS)
CD-ROM/DVD (D:) : N/A
Peripherals
USB Controller/Hub : Standard OpenHCD USB Host Controller
USB Controller/Hub : Standard Enhanced PCI to USB Host Controller
FireWire/1394 Controller/Hub : Texas Instruments OHCI Compliant IEEE 1394 Host Controller
Keyboard : HID Keyboard Device
Mouse : PS/2 Compatible Mouse
Mouse : HID-compliant mouse
Human Interface : USB Human Interface Device
Power Management
Operating System
Network Services
Network Drivers Enabled : No
Performance Tips
Ozmo Lux'lucis
Taraxacum Officinale
  #968
Old 04-05-2007, 04:54 PM
Ccroft Ccroft is offline
Please help me out. I recently aquired a digi 001 and im having problems getting it to work in either of my two systems. My main system reads the hardware but when i execute protools 6.4 it reboots my pc everytime here are its stats
System 1
Host Name : DAW
User : Pro Tools
Workgroup : MSHOME
Processor
Model : AMD Athlon(tm) 64 Processor 3000+
Speed : 1.81GHz
Model Number : 3000 (estimated)
Performance Rating : PR3256 (estimated)
L2 On-board Cache : 512kB ECC Synchronous, Write-Back, 16-way set, 64 byte line size
Mainboard
Bus(es) : ISA PCI PCIe USB FireWire/1394 i2c/SMBus
MP APIC : No
System BIOS : Award Software International, Inc. F9
Mainboard : Gigabyte Technology Co., Ltd. GA-K8N Pro-SLI
Total Memory : 1GB DDR-SDRAM
Chipset 1
Memory Bus Speed : 2x 201MHz (402MHz data rate)
Video System
Adapter : NVIDIA GeForce 7300 LE
Removable Drive : Floppy disk drive
Hard Disk : Maxtor 6E030L0 (29GB)
Hard Disk : WDC WD800JB-00JJA0 (75GB)
Hard Disk : WDC WD800JD-22LSA0 (75GB)
CD-ROM/DVD : SAMSUNG CD-R/RW SW-252B (CD 52X Rd, 52X Wr)
Hard Disk (C:) : 75GB (5.6GB, 8% Free Space) (NTFS)
Hard Disk (D:) : 29GB (26GB, 90% Free Space) (NTFS)
Data (E:) : 75GB (46GB, 62% Free Space) (NTFS)
GIGABYTE (F:) : 572MB (CDFS)
3.5" 1.44MB (A:) : N/A
Peripherals
USB Controller/Hub : Unknown Device
Infrared Device : Built-in Infrared Device
Mouse : Logitech USB TrackMan Wheel
MultiMedia Device(s)
Device : Digidesign Digi 001
Power Management
Operating System(s)
Network Services
Performance Tips
Warning 100 : Large memory sizes should be made of Registered/Buffered memory.
Tip 2546 : Large memory modules should be ECC/Parity.
SiSoftware Sandra
Device Information
Device Type : Other Multimedia Device
Device ID : bus 1, device 8, function 0
Windows Device Name : Digidesign Digi 001
OEM Device Name : Motorola 56301 Audio I/O Controller (MIDI)
OEM Hardware ID : FUN_0, VEN_1057, DEV_1801, REV_03
Device Name : Pro-Log Corp/AVID Technology Inc 56301 Audio I/O Controller (MIDI)
Product ID : VEN_11AF, DEV_EEB0
Revision : A / 4 (3)
Device Capabilities
Line Cache Size : 8 byte(s)
Latency Timer : 255 clk
I/O Range : No
Memory Range : Yes
Bus Master Capable : Yes
Special Cycle Recognition : No
Memory Write & Invalidate : No
VGA Palette Snoop : No
Parity Error Response : No
Address/Data Stepping : No
System Error Line : No
Fast back-to-back Transactions : No
Detects Parity Errors : No
Supports System Error Line : No
Supports Parity Line : No
User Defined Format : No
66MHz Bus Support : No
New Capability List : No
Device Select Timing : Medium
Multi-Function Device : No
Header : 00
Interface : 00
Hardware Resources
Memory Range : F4000000
Irq. No. : 16
INT Pin : A#
Dynamic Management : Yes.
System two is a slightly older pc with a amd 2500 cpu and a gigabyte MB with the via chipset
Pro Tools will execute on that one but it will not read the pc card.
I thought getting a Pro Tools setup would be a joyous occasion, but i'm starting to think that paying homeless people to kick me in the crotch would have been a better way to spend my money and less painful ; ;
  #969
Old 04-06-2007, 05:35 PM
Lonald Lonald is offline
The problem I'm having is constant interrupts during recording and playback. I've tried changing the buffer size and everything, but that isn't helping. I am constantly reducing/increasing it.
Processor
Model : AMD Athlon(tm) XP 2400+
Speed : 2.00GHz
Model Number : 2400 (estimated)
Performance Rating : PR2953 (estimated)
L2 On-board Cache : 256kB ECC Synchronous, Write-Back, 16-way set, 64 byte line size
Mainboard
Bus(es) : ISA AGP PCI USB FireWire/1394 i2c/SMBus
MP Support : No
MP APIC : No
System BIOS : Award Software International, Inc. 6.00 PG
System : VIA Technologies, Inc. VT8366-8233
Mainboard : DFI AD70-SC
Total Memory : 1.5GB DDR-SDRAM
Chipset 1
Model : VIA Technologies Inc VT8366/A,VT8367 Apollo KT266/A,KT333 CPU to PCI Bridge
Front Side Bus Speed : 2x 133MHz (266MHz data rate)
Memory Bus Speed : 2x 133MHz (266MHz data rate)
Video System
Adapter : NVIDIA RIVA TNT2 Model 64/Model 64 Pro (Microsoft Corporation)
Hard Disk : SAMSUNG SV8004H (75GB)
Hard Disk : ST3120814A (112GB)
CD-ROM/DVD : Memorex 40MAXX 1248AJ (CD 170X Rd, 40X Wr)
CD-ROM/DVD : SONY iLINK DRIVE IEEE 1394 SBP2 Device
Hard Disk (C:) : 75GB (35GB, 46% Free Space) (NTFS)
Local Disc (D:) : 112GB (57GB, 51% Free Space) (NTFS)
Peripherals
Serial/Parallel Port(s) : 2 COM / 2 LPT
USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller
Device : MPU-401 Compatible MIDI Device
Device : Standard Game Port
Device : CMI8738/C3DX PCI Audio Device
Device : Communications cable between two computers
Printers and Faxes
Model : HP PSC 1500 series
Model : Final Draft PDF Converter 2
Power Management
Operating System(s)
Network Services
Adapter : Instant Wireless-B PCI Adapter
Performance Tips
  #970
Processor
Speed : 2.00GHz
Mainboard
MP Support : No
MP APIC : No
Chipset 1
Video System
Peripherals
Printers and Faxes
Power Management
Operating System(s)
Network Services
Performance Tips
Closed Thread
Problems with PTLE? Post your configuration here...... still_life_ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-30-2007 12:27 AM
Problems with PTLE? Post your configuration here.. DJ John 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-28-2007 10:06 AM
Problems with PTLE? Post your configuration he krsongs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-28-2007 09:59 AM
Problems with PTLE? Post your configuration here.. p3tch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-28-2007 09:46 AM
Problems with PTLE? Post your configuration here.. Gaba 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-23-2007 08:01 AM
