Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools SE and Essential (Mac)
Old 12-13-2010, 02:17 PM
Sound Student Sound Student is offline
Default How do I boost the gain while recording?
When I record voices they always come out too low. In order to make the audio clip reach the levels I need it to reach I need to boost the gain then double it with itself. Is there a way I can avoid doing all that and just record the voice at the level I want it? Is there a way to boost the gain while recording? (Is that even the best way to go about it?)
Old 12-13-2010, 03:35 PM
Default Re: How do I boost the gain while recording?
I posted this is in the wrong forum
Old 12-14-2010, 02:38 AM
chrisdee's Avatar
chrisdee chrisdee is offline
Hello.
What equipement are you using. Soundcard, preamp, microphone, cables, software etc.
How do you connect (through mic input or line input) ?
When recording vocals you should connect the microphone to the soundcard microphone input (wich usually has a built in preamp) with a microphone cable.
If it doesn't have a built in preamp you need an external preamp wich you connect to the line input of your soundcard.
When everything is connected right you start setting the input level on your built in or external preamp untill you get a sufficient signal.
For me thats between -18 dB and -12dB. Peaks can be a bit higher but try to make it even while recording.
gain,volume and boost on the bogner timos Eleven Rack 3 04-03-2011 06:41 AM
Gain Levels...recording StainedClass Pro Tools TDM Systems (Mac) 65 03-28-2003 09:11 AM
Gain Boost on Conversion Deirdre B Digidesign Hardware & Software 5 10-15-2002 06:01 PM
Boost recording...? go i huvet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 02-08-2002 05:14 PM
Using gain on master fader plug-ins to boost overall level? flymax Tips & Tricks 1 04-16-2001 03:05 PM
