Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 03-07-2020, 03:40 AM
Cayce Cayce is offline
Default Mysterious Signal Drop on Master Strip
I've got something going on here I can't figure out. With a Neumann mic going into my Vocals track, and that track going directly into my Master channel, there's a significant drop in signal. The vocal strip is new, empty: no plugins, sends, nothing. Shouldn't the signal in the Master be identical to what's showing on the vocal meter?
See the attached image for the difference in a constant tone fed to the mic and what shows in the Master.
Thanks.
iMac (Retina 5K, 27-inch, Late 2015)
4 GHz Intel Core i7
32 GB 1867 MHz DDR3
2TB Internal Fusion Drive
2 4TB External Drives with Mirrored Backups
2 External Monitors: 27" & 65"
Old 03-07-2020, 04:15 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: Mysterious Signal Drop on Master Strip
Pans law. Or different meter settings.
Pan hard left or right and see the difference.
Level should match.
The amount of middle-dip can be adjusted in session setup (command keypad-2).
(Help us Help You)<<<click here
APFS 90% 10% Audio on Both.
Pro Tools U-2020.5 macOS 10.14.6 APFS
Second boot-macOS 10.13.6 (Avid HDX-1 Omni)
(2k10MP 5,1 / 64-Gb)
(Sapphire RX-580 MVC-Edition-dual mini 6 pin. one spliced to add Avid mini 4 pin-hdx)
FW-CoreAudio (for poly-recording)
(SSL-HUI-MIDIoverIP)
music-design-creation
Post Music-Sound mixing, Production-Enhancements.
Audio Tuning and System Services
new systems builds / upkeep / +
New builds:
12 core nMP HDX 1 Slot 5 stock HDX Mac mini 6pin to 4 pin HDX power like 5,1 mp's used)
16 core nMP rack-test station
28 just because machine
Old 03-09-2020, 07:29 AM
off the wall's Avatar
off the wall off the wall is offline
Pan rules shouldn't account for that much difference (3db is default in PT). I suspect meter type differences as well
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, AMD 7970 GPU, SSD boot drive on 6Gb/sec PCIe card, 64GB RAM, MacOS 10.14.6.
Pro Tools Ultimate 2020.5. HDX, UA Octo PCIe cards, HD I/O, C|24 control surface.
Mostly Avid, Waves, Sonnex and UAD Plug-ins
Genelec 1031AP/7070A 5.1 monitoring.
Old 03-09-2020, 07:52 AM
Definitely different meter types for channel and master - obvious from the meter scales on the two faders.
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.14, PT 2020 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24.
Old 03-13-2020, 04:44 AM
Thanks for all the help. Turns out it was the meter type difference. Learned something valuable there.
Thanks again.
4 GHz Intel Core i7
32 GB 1867 MHz DDR3
5.1 Pathway is not showing up in Master Output Drop Down Menu Audiooo Pro Tools 2018 2 04-26-2019 09:04 AM
Has anybody noticed if the signal generator has frequency drop outs phatbeatstudio Pro Tools HDX & HD Native Systems (Mac) 11 05-19-2012 10:02 AM
Waves' S1 on Master fader question: Huge volume drop? fingerz88d 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-07-2003 10:34 PM
Channel Strip on Stereo Master Fader stevemusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-15-2002 08:25 PM
Channel Strip and Master Fader fifty8th1 Tips & Tricks 5 06-07-2001 02:56 PM
