  #21
Old 05-21-2020, 01:40 PM
Default Re: Pro Tools 2020.5
Originally Posted by originalscottyg View Post
I searched for Avid Control in the App Store app, then tapped on the app to go to the details page. There is an Update button and the version says 20.5.0.
Avid Control 20.5 app working fine with EuCon 20.5 and PT Ult 2020.5 on 10.14.6. Opening and closing folders from the app is cool. I wish there was an easy way to open and close folders from a surface (i.e. Artist Mix/S1/S3). But that may be coming in another update, as Folder Spill is supposed to be coming as well.
Only weird thing that happened, was that it actually took a bit of clicking to get my stored layouts to show up in the drop down in the app for a session I was working on yesterday. I created a new layout and at some point the old ones just showed up.
On the plus side, an OMF that gave me the Bento error yesterday on 2020.3 imported fine on 2020.5.
Scott Gatteño
Yessian
  #22
Old 05-21-2020, 01:41 PM
sonmelo sonmelo is offline
Thank you, JFreak! :)
  #23
Old 05-21-2020, 01:45 PM
massivekerry massivekerry is offline
Hey Scott. What Machine? Thanks.
  #24
Old 05-21-2020, 01:57 PM
MacBook Pro 15" 2019
2.3GHz i9 32GB RAM
Radeon Pro Vega 20 4GB
macOS 10.14.6
PTU 2020.5 HD|Native TB + Omni
EuCon 20.5
iPad 6th Gen iOS 13.3.1
Artist Mix
Scott Gatteño
Yessian
  #25
Old 05-21-2020, 02:34 PM
lampmusic lampmusic is offline
Compatibility document says approved for Catalina 10.15.3.
We just got a new MBP 16 yesterday and have been testing it with our setup. It was pre-loaded with 10.15.4. I have not yet discovered if there's a way to roll that os back to .3.
How many are using 10.15.4 sucessfully?
Main System MBP 2016 (touch strip) 16G Ram.
I own a PTHD 11 which I still use on a native system in main studio (not sure if is worth the $ for reinstatement)
Doing most of my mixing work in PT 12 vanilla.
OS X 10.12.6
  #26
Old 05-21-2020, 02:40 PM
10.15.4 working wonderfully here but it took me half a week to do a VERY clean install. And there is a difference even with a factory install and emptying your system drive.
  #27
Old 05-21-2020, 02:50 PM
2.3GHz i9 32GB RAM
macOS 10.14.6
EuCon 20.5
Artist Mix
Thanks much! Same as my portable rig. I'll test that one first then.
  #28
Old 05-21-2020, 03:01 PM
off the wall's Avatar
Default Re: Pro Tools 2020.5 - hidden tracks?
Is anyone else seeing an issue with previously hidden and deactivated tracks becoming unhidden when the session is opened in 2020.5?
I have three mixes that I just completed last night on 2020.3. All three were long term projects, through many versions, revisions, edits, etc so there were large blocks of tracks de-activated and hidden with just the recent ones relevant to the mix visible.
I opened all three up today in 2020.5. In all cases, large blocks of hidden/deactivated tracks were unhidden. Not all and no pattern that I could discern. Maybe something related to changes they made in folders or groups? It did make for an annoying mess.
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, AMD 7970 GPU, SSD boot drive on 6Gb/sec PCIe card, 64GB RAM, MacOS 10.14.6.
Pro Tools Ultimate 2020.5. HDX, UA Octo PCIe cards, HD I/O, C|24 control surface.
Mostly Avid, Waves, Sonnex and UAD Plug-ins
  #29
Old 05-21-2020, 03:46 PM
Juan Garcia Juan Garcia is offline
I didn't do so well. Installed EUCON 2020.5, then all went south. Went with PT 2020.5 instead, hoping for the better, with no luck.
Pro Tools crashed at startup. Managed to use Pro Tools by trashing prefs but cannot enable EUCON atm. Pro Tools hangs up when trying to enable EUCON. Your mileage may vary.
macOS 10.13.6
Pro Tools 2020.5 (previously 2020.3)
EUCON 2020.5
Best,
J.
  #30
Old 05-21-2020, 06:22 PM
abc1mce2's Avatar
abc1mce2 abc1mce2 is offline
macOS 10.13.6
EUCON 2020.5
Best,
J.
Did you update the Avid Control App?
What is more relaxing then Music?
GigabyteX79-UP4 Rev 1.1
Xeon E5 2680 v.2. 10 Core cpu Windows10 v.1909
Avid HDX 2019.10 HD - 16x16 - 8x8x8 HD I/O - PT Dock - PT Control - AVID Artist Mix (2)
Universal Audio UAD2 Pci-E and Satellite USB Octo - Pci-E Quad - SOLO 610 - Twin-finity
Antelope Trinity - 10M
Grace Design M905
Bricasti M7 (2)
Lexicon PCM96
Burl B2
Dangerous 2Bus
Neumann KH805 - KH310
Yamaha NS-10M
Avantone Mixcubes
Etc, etc, etc.
Pro Tools (2020.3) on MacBook Air 2020 compatibility pellekuipers Pro Tools 2020 1 04-04-2020 08:01 AM
Pro Tools 2020.1 off the wall Pro Tools 2019 138 01-21-2020 07:12 PM
New Avid Link 2020.1 - launched today 1/16/2020 marianna Licensing & Accounts 8 01-16-2020 11:43 PM
