I'm wondering if there is any way to access Logic's Spacedesigner plug-in while working with Logic in the DAE mixer. It appears that things can be routed from the DTDM mixer into the DAE mixer but not vice-versa. I'm pretty sure the Spacedesigner plug-in can only reside in the DTDM mixer. If I switch the DAE track to be processed to a DTDM track, I lose out on the DAE plug-ins for that track. Is there something I am missing, or is there a workaround?
Thanks, Lawson |
As you assume it's a oneway signalflow.
Two ways I come to think of would be: #1 Create a copy of the DAE-track on a DTDM track. Simply create sends from that track to a "Space-Designer aux return", that you bus to the DAE-mixer. You don't need to send the dry DTDM-track to the DAE-mixer. Of coarse, in this scenario you don't have the inserted plugins of the original DAE-track, but you could do something similar with Logic/AU-plugins. #2 If you have a track that sounds good without to much processing, (and don't mind sending the Space-Designer before TDM-plugins are engaged, you could just bus your DTDM-track (after sending to Space-Designer, which would also be bussed to DAE via ESB) to the DAE-mixer and add plug-inserts (EQ/comps etc) Maybe too obvious, and not what you meant?
PT Ultimate 2020.3 | HD OMNI | S3 | PT Dock | EuControl 20.1.0.50 | PT Control 20.1.0.8 macOS High Sierra 10.13.6 | Nehalem Mac Pro (FW 5,1), 2 x 3,46 GHz 6-Core Intel Xeon, 128 GB 1333 MHz DDR3 |
drpopkit,
Of course, that makes perfect sense. I can play back the audio track in DTDM and bus it to Spacedesigner. I can then route both of those seperately back to DAE and process the original track with DAE plug-ins. Don't know why I didn't think of that. Thanks, Lawson |
Logic/PT is a great combo, now only if we'd get two-way signalflow.
And more than 8 busses with ESB (4 stereo)...
Logic7 w/SpaceDesigner&EVP88 inside of ProTools6.4 | M2E | Pro Tools TDM Systems (Mac) | 1 | 05-08-2006 07:01 PM |
Can You Use Logic's Plug-Ins in Pro Tools LE? | pianoman_78 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-01-2006 04:28 PM |
pro tools 001 & logic's esx24? | microDAT | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 12-28-2002 07:03 PM |
something comparable to Logic's catch? | shawnuff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-26-2002 02:28 AM |
Can I use Logic's EXSP sampling with PT LE? | Jarabee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-25-2002 07:22 AM |
