Old 12-10-2018, 11:20 PM
Default Re: Real time SR conversion via spdif - Avid HD IO
Originally Posted by Eric Lambert View Post
I don't have the added digital IO card, so... that means I'm out of luck with the realtime conversion idea?
Oh, yep Eric you are out of luck. No chassis digital connectors support sample rate conversion.
So... you can pick up HD IO digital cards for under $500 on EBay if you have a slot free and then go from S/PDIF to AES/EBU.
Alternately if you have DigiLink capacity, add a 192 IO box which has sample rate conversion on the digital daughter cards as well and you should be able to pick up as a whole 192 I/O with digital (and analog) cards for a few hundred dollars.
Or... you really want a new MTRX anyhow right? (sample rate conversion on AES/EBU as well)
BTW please let us know what you think of the Ox... what a kitchen sink of features (but doh should have had AES/EBU out for pro-studio use)... but UAD themselves just don't do much AES/EBU on their interfaces (a pet peeve of mine).
Old 12-11-2018, 12:13 AM
Oh just in case you have an Omni laying around... they have sample rate conversion on their inputs... including S/PDIF coax and optical.
Omni on EBay... ~$800-$1k?
Old 12-11-2018, 12:34 AM
Eric Lambert's Avatar
The OX is fantastic. It's early in the game but it's been exceeding my expectations which have been high for this kind of thing. The only gripe I have at this point is the issue of this thread. Yes, the lack of an AES connection feels like a mistake for this product.
Old 12-11-2018, 11:22 AM
I'd say the lack of any other sample rates than 44.1kHz is the biggest mistake IMO.
Scott Gatteño
Yessian
Old 12-11-2018, 12:36 PM
The option for 48, or higher, would be nice.
Old 12-11-2018, 12:38 PM
I compared the digital and analog outs and digital has a slight edge. More detail, faster attacks, more bite. The usual.
Some of this detail would be lost in a 44.1-->48 conversion so I'm not sure which is the lesser of two evils -- analog or a SR conversion -- but I'm going to continue to search for a graceful way to get this signal to 48k.
Old 12-11-2018, 01:01 PM
My first thought was, why not run it at 48kHz. I had to download the manual to see for myself. The idea that someone would make a new piece of gear with digital outputs that only work at 44.1kHz is mind-boggling to me. I wonder what the reasoning behind that decision was.
Scott Gatteño
Yessian
Old 12-11-2018, 01:56 PM
I suspect it is all to do with driving the speaker emulation etc. software. Which may upconvert internally to further complicate things. I expect UAD want to optimize for that/simplify things by supporting one sample rate. Anyhow the decision is likely to be lead by that not just simple digital input/output implementation... there are no reasons there.
IIRC UAD has sample rate conversion on all their interfaces, and only do AES/EBU on their Apollo 16... so I think they blinded themselves to some mistakes here.
Old 12-11-2018, 02:14 PM
So... anyone know of a small, external, high-quality sample rate convertor?
(but seriously, I do need one)
Old 12-11-2018, 02:39 PM
None of the Avid interface ideas work? The only high-quality converters I have seen in use are the various RMI models, not cheap.
Spdif RCA to Spdif Optical conversion - degradation?? Hollow Body 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-17-2011 09:21 AM
Real-Time Bounce to Disk...REAL PAIN Brian in Charlotte 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 201 07-26-2010 09:12 AM
File Conversion-W/O real time play down STUDIO 44 Pro Tools TDM Systems (Mac) 4 08-26-2005 02:54 PM
real time Sample Rate Conversion nukmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-15-2004 07:46 PM
Capture range for real time SR conversion KK Proffitt Pro Tools TDM Systems (Mac) 0 10-19-2004 02:44 AM
