Old 09-13-2017, 10:05 AM
SomeOtherGuy SomeOtherGuy is online now
Default Pro Tools MIDI Real Time Properties DLY bug
In Real Time Properties if you set the DLY function to a negative value to compensate for slow attack on MIDI strings, the compensation will only work on every note in the phrase PAST the first note, which will unfortunately play way too early (since the negative DLY compensation for some reason doesn’t work on this first note of a phrase and will well ahead of the beat). I realize this is most likely a bug, but has anyone found a way around it? Some way to trick it perhaps?
Pro Tools Ultimate 2019.6, Avid MTRX, MOM, Mac Pro 3.5 Ghz 6-Core (2014) 64 GB RAM, Mac OS Mojave, Samsung T5 SSDs
Old 09-13-2017, 10:18 AM
Default Re: Pro Tools MIDI Real Time Properties DLY bug
I found this thread on Ideascale:
http://protools.ideascale.com/a/idea-v2/78872
Apparently this is a long standing bug. What's up with Avid that they can't address these little troublesome things, when they tout that Pro Tools is the industry standard? Shameful.
Old 09-13-2017, 10:26 AM
TheNeil's Avatar
TheNeil TheNeil is offline
Interestingly, the status of the idea is Completed though. Perhaps it was fixed in older versions and then came back at some point.
Pro Tools 2018.1 (Non-HD) | macOS High Sierra | 2.6 GHz Intel Core i7 | 8GB RAM | 7200rpm SATA Drive | iLok Cloud | Line6 POD UX2 | 256 Sample Buffer | 1 GB Cache
Old 09-13-2017, 10:43 AM
Yes, hard to know if this is related to the playback bug, it may not be...
midi real time properties issues End Over End Windows 0 03-14-2014 12:38 PM
Question about midi real-time properties mahag macOS 2 05-05-2013 12:54 PM
Real Time Properties in MIDI w/ regard to Playlists Kourquie Pro Tools TDM Systems (Mac) 11 04-03-2009 05:07 PM
Problem with real time MIDI properties Ray Lyon Pro Tools TDM Systems (Mac) 0 10-30-2006 06:54 PM
