Automation Dialog Access in Groups
Is there a shortcut to add parameters for a plug-in in the automation dialog window to all tracks in a group? That sounds kind of clumsy; here's what I'm trying to do:
Multiple vocal tracks have a particular compressor inserted. I'd like to add threshold and gain to the parameters I can access and change here and there throughout a session. PT 12.4 Windows 10
"Modern manufactured music is like art they sell at a furniture store." http://www.weddingmusicproject.com/ http://www.weddingmusicproject.com/w...music-samples/ http://stevemillikan.com/ |
Re: Automation Dialog Access in Groups
But if you select the Pref "plugins default to auto enabled", then they already will be and when you link the insert in the group dialog, they'll all follow. |
Excellent, thanks for the tip.
When I have a similar situation I put the plug ins in the same slot and then link them via a group. SO if I adjust a parameter that same adjustment gets adjusted on all grouped tracks with the plug in in the same slot. I do not think its relative adjustments, so all the settings have to be the same on all tracks.. So with multiple tracks of background vocals for example eq's and whatever plugs ins can be linked so change 1 and they all match. the groups have multiple pages and can be flexible for this type of thing. Maybe have to peruse the manual to make sense of it but have a poke around and see.
Jay-J System MacPro 12 Core • 24 G Ram • 10.12.6 PT 12.8.1 • Mbox 3 Pro • Plug-ins Verified 4 HD • OS ssd | Audio ssd | Sample Library ssd | Storage MAXPower eSATA 6G Card • Wiebetech RTX100H-Q Kensington Trackball Works/Orbit Optical Bluetooth off/Airport on and off. |
You can change them on one then copy-special that automation to all the others. Sent from my iPad using Tapatalk |
Automation and VCA groups | Audioartist | macOS | 0 | 04-26-2015 01:46 PM |
Lost access to mix groups in mix window | digidesigner | Pro Tools TDM Systems (Win) | 0 | 06-01-2011 10:17 AM |
access violation errors on create region groups? | dawkab | Pro Tools TDM Systems (Win) | 0 | 09-12-2006 11:52 PM |
cant access help dialog box | poketools | Pro Tools M-Powered (Win) | 0 | 09-02-2005 06:54 PM |
Can't access Hardware Setup Dialog??? | Jepse | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-18-2005 09:54 AM |
