Re: Bug report: VCA won't follow group
Hi follow these steps to reproduce this issue;
Create 4 mono audio tracks, group them (volume and mute) . -you can now change volume of group by moving any fader in the group or by drawing breakpoints. -as expected. Add a VCA track to this group -if you move a fader on the VCA the other members of the group don't change, if you move a fader on the audio tracks ONLY the audio tracks move, if you draw a break point it draws on all grouped tracks VCA and AUDIO tracks. -the unexpected behaviour is that the VCA fader will not move as part of the grouped audio tracks when you move the faders on mix or edit page. Probably not a deal breaker but pretty odd. Cheers Bruno |
thx for the clarity ...
That's the bug right there.
Lior HD Native * PT 2018.12 * OS X 10.13.6 * MacPro 12 Core * 2.4GHz 24GB Ram * 2XUAD2 Octo * Waves Platinum * Lexicon PCM Native Bundle * Sound Toys Bundle* AutoTune8 * NI Komplete11 * BFD3 * Synthogy Ivory II* Vienna Ensemble Pro * Spectrasonics * Slate trigger2 *xFer records * Softube * Vienna Ensemble * DMG Expurgate * Massey DRT2 * iPad Air/Avid control * EuCon 18.3.0.217 * |
In ProTools -VCAs are only added as Type "EDIT Groups" ... MIX groups or MIX/EDIT is not possible with VCAs
If you want to make a mix or mix/edit group of VCAs (Or a mix or mix/edit group of audio tracks and also include VCA fader/s) The work around is to make another VCA that controls that group. Cheers Bruno Last edited by SBP; 07-01-2017 at 09:34 PM. |
This is how VCAs within groups have worked as long as I can recall using them. Unless i'm missing something, this definitely isn't new to 12.8. For sanity sake I launched 10.3.10 and the behavior is there as well, as expected.
pqlior, does this change the behavior to what you remember ??? i found this on Sound on Sound this morning .. the Bold is mine .. It is possible, if you want to, to turn off these different group functions and make a VCA group function like a normal group. In the Mixing tab of the Pro Tools Preferences window there is an option called 'Standard VCA Logic for Group Attributes'. Deselecting this option means that VCA groups function more like conventional groups; so, for example, hitting a slave track's solo button makes the solo buttons on all the slave tracks come on. It is also possible for slave tracks to be members of more than one VCA group, in which case the contributions from all the VCA Master faders that are connected to them are summed together. Mute, solo, input monitor and record enable all follow the normal rules, and VCA Masters can even be nested inside another VCA group. i may become a VCA convert !!! cheers john
VCAs shouldn't be made members of mix groups.
Especially not their own mix group. Behavior seems normal to me.
Steve
Steve Shepherd Extreme Mixing |
My understanding was that VCA's are used to control a mix group(s). I never thought to assign a VCA to a mix group nor have I seen it done... even in any tutorials.
What is more relaxing than Music? Pro Tools Carbon for macOS 12.7.4 My HDX for Windows11. Gigabyte Z490 Vision D - BIOS F21b Intel Core I9 10850K Windows11 / macOS 12.7.4 Hackintosh / 32GB of Rams Avid Carbon/HDX 2024.3 Ultimate - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (1) Universal Audio Apollo Twin|X - UAD2 Pci-E and Satellite USB Octo v.11.0.1 - SOLO 610 - Twin-finity Bricasti M7 (2) Lexicon PCM96 Neumann KH805 - KH310 Yamaha NS-10M Avantone Mixcubes Grace Design M905 Etc, etc, etc. Last edited by abc1mce2; 07-01-2017 at 07:10 PM. |
bug report-- solo playlists among grouped tracks only works if mix group is selected | Gems Records | Pro Tools 11 | 4 | 12-26-2013 09:21 AM |
New group default to "Follow Globals"? | reichman | Post - Surround - Video | 0 | 07-05-2011 12:35 PM |
1 track in group isn't responding with group! | gregwor | macOS | 7 | 01-25-2011 07:22 PM |
Follow up please | Fastermouse | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-20-2008 10:45 AM |
Group Persists for Resizing Even When Group Turned Off. | holden | Pro Tools TDM Systems (Mac) | 3 | 06-24-2008 03:31 PM |
