BUG: Multiple output assignment key combo broken…
A keyboard combination I rely on heavily does not seem to work anymore (Mac).
I generally send my drums to two subgroups for parallel processing: one called "Drums" and the other called "Drum Crush". Normally I select my drum tracks and while holding Shift-Option I select the "Drums" subgroup. This assigns all the drums to the "Drums" subgroup. So, far, so good. To assign the same drums to the "Drum Crush" subgroup in addition to the "Drums" subgroup I hold down Shift-Cntl-Option and select the "Drum Crush" subgroup. After installing 12.8 HD this no longer works. I can assign each track individually by holding Shift-Ctl but the "Opt" option doesn't work. Is anyone else experiencing this or recreate this bug? Thanks
www.chrisshawmix.com PT 20.3.0 S1 x2 Artist Transport Avid Control iPad 7th Gen HD Native Hackintosh i9 3.6 GHz Six Core MTRX Studio OSX 13.6.4 Last edited by cshaw; 06-28-2017 at 06:54 PM. |
Re: BUG: Multiple output assignment key combo broken…
and in 12.7.1.733 this works fine .. i will send this in to the Authorities !!!!
Macmini M1 8/512 -OS 12.3.1 and PT2022.4 Logic Pro X 10.7.4 RME BabyFace Pro Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3 Logic Pro X 10.7.4 RME BabyFace Pro Last edited by john1192; 06-28-2017 at 07:08 PM. Reason: addition .. |
Ugh! Bugs quashed and others pop up…
www.chrisshawmix.com PT 20.3.0 S1 x2 Artist Transport Avid Control iPad 7th Gen HD Native Hackintosh i9 3.6 GHz Six Core MTRX Studio OSX 13.6.4 |
Shift + Control + Option -to assign additional output or bus to all selected tracks... is working here. PThd12.8.0 MacOS10.12.5
Cheers Bruno |
Hmmm. I'm on OSX 10.10.5.
Ok, time to trash prefs… Sent from my iPhone using Tapatalk
tossed prefs and restarted .. same thing .. tested in a BLANK Session .. not working ..
Yep. Same here. Trashed prefs and still no go.
How does one bring this up to Avid? This is a serious (though non lethal) bug.
consider it done !! wink wink ...
Are other +option modifier keys working for you guys? Cheers |
PT quits every time I change an output assignment | fm_xtk | macOS | 4 | 05-18-2017 05:52 AM |
Artist Mix - Eucon 3.0 introduces a new output/bus assignment scheme in Pro tools 11 | Emcha_audio | Artist Series | 1 | 09-24-2013 01:39 AM |
Output assignment bug | pmklein | Pro Tools M-Powered (Win) | 0 | 07-01-2009 05:00 PM |
Structure output assignment problems | Extreme Mixing | Virtual Instruments | 0 | 11-19-2007 02:19 PM |
Multiple Track Assignment to Auxes in LE | Girl6 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-27-2006 06:18 AM |
