(SOLVED)No MIDI input activity and no sound from VIs - but PT actually records MIDI!?
This is really strange - probably a bug?
It appears that Pro Tools does not receive any signals from my MIDI Controllers. When I enable record on the MIDI track, there is no activity on the input meters when I play my keyboard. If I route the MIDI track to a VI (tried several; omnisphere, kontakt ++), there is no sound. BUT! When I start to record, Pro Tools records every key I press on the keyboard, but there are no sound from the VI and no activity on the input meter. And probably even more strange: When I playback the MIDI track, the VI plays just fine! It is not acceptable to be unable to hear what I play until after I have recorded a take, so I have to figure this one out! Has anyone else experienced this? I have not had this problem before. I am on 10.2 (+CPT2) on Snow Leopard. |
Re: No MIDI input activity and no sound from VIs - but PT actually records MIDI!?!?
Just wanted to add that there is a small sign of midi activity: When I enable record on the track, a tiny green bar (say 2%) appears for a few ms before the track monitor dies completey.
Check that options>MIDI thru is ticked (ie switched on).
Thank you so much!
I haven´t used PT for midi before, so I understand now that there are a few things to read up on :) |
MIDI Input from keyboard, lag before hearing sound | danjfoley | Windows | 3 | 01-13-2014 01:55 PM |
dr 770 (boss dr rhythm 770) as midi controller/midi output to 11r midi input | yellow | Eleven Rack | 1 | 05-04-2012 03:33 PM |
Midi records but does not sound during playback | jbarratt | Virtual Instruments | 1 | 02-16-2009 01:30 PM |
no sound on input 3 and 4 and midi problems!!!!!!! | seasondigital | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-21-2007 08:44 AM |
no midi activity | sssoundsss | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 06-07-2004 08:57 AM |
