New SDII format?
Is PT 5.1 using a new Sound Designer II format? First, the icon has changed to a colored one. Second the old files have no specific icon. Third, when I listen to sound regions from the Import Audio menu, it sometimes causes PT to crash and the audio interface to output a big annoying high pitched sound. I have experienced that on both my systems, on a G4 and a 9600.
Re: New SDII format?
I think the only thing changed about the SDII files are the unique file identifier. The colored ones signify files having been generated from PT 5.1 and having the identifier.
SoundApp still sees 'em as good ole SDII files. There is something weird with Pro Tools 5.1 and how it acquires the hardware. A few times, when opening Microsoft Word while PT is open, Pro Tools would geek and say it couldn't reacquire the hardware. Active in background was off, Pro Tools was idle, but the all sound was being pumped through the Digidesign outputs, as opposed to the Mac built-in outputs. *shrug* |
GROINK:
There must be something more to it than that. If you have the preference in PT checked for AES31 compatibility mode and attempt to import SDII files from a previous version of PT you get a dialog box which says the files must be converted first. Uncheck that pref box and they import without a problem. PT5.1 seems to add some additional info for BWAV/AES31 compatibility (perhaps for PT on Windoze). Anyone know the answer? -Polaris
Polaris |
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by midimac:
Third, when I listen to sound regions from the Import Audio menu, it sometimes causes PT to crash and the audio interface to output a big annoying high pitched sound.<HR></BLOCKQUOTE> This is a 5.1 bug that is supposed to be fixed in 5.1.1 |
SDII File Format; When Was It Dropped ? | priorytools | Pro Tools TDM Systems (Mac) | 9 | 06-16-2013 02:55 PM |
Converting a SDII file from mac format to pc..HELP | KemikAL | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-05-2003 02:55 PM |
Converting a SDII file from mac format to pc..HELP | KemikAL | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-05-2003 01:55 PM |
What file format should I use - Wav, SDII etc...? | everglass | Pro Tools TDM Systems (Mac) | 6 | 05-13-2002 10:01 PM |
SDII file format for Post | DigiTechSupt | Post - Surround - Video | 7 | 11-30-2001 11:06 AM |
