Old 01-02-2021, 12:27 PM
creativecontrol's Avatar
Default MTRX IO Delays
Greetings,
This is a work in progress, however I wanted to start in on the discussion of patching different types of IO into MTRX family devices and determining the appropriate delay values. Here's the start of that. Please note that all of the Digi Delay values being used here are 7 samples - which is the default when you have the monitor section (Pro|Mon) enabled on MTRX with a monitor profile loaded. We can discuss more on that - but for now I would always recommend using the 7 sample value for consistency. Hopefully this will be a helpful starting place before we can get some of this put into an article on the Avid Knowledge Base.
[MTRX Studio]
44.1kHz: MTRX Studio: AD -> DA, Hardware Insert Delay = 1.27ms
44.1kHz: MTRX Studio: ADAT -> ADAT, Hardware Insert Delay = 0.18ms
44.1kHz: MTRX Studio: Dante -> Dante, Hardware Insert Delay = 0.17ms
44.1kHz: MTRX Studio: Dante -> AVIO (AES) -> Dante, Hardware Insert Delay = 5.39ms
48kHz: MTRX Studio: AD -> DA, Hardware Insert Delay = 1.18ms
48kHz: MTRX Studio: ADAT -> ADAT, Hardware Insert Delay = 0.16ms
48kHz: MTRX Studio: Dante -> Dante, Hardware Insert Delay = 0.16ms
48kHz: MTRX Studio: Dante -> AVIO (AES) -> Dante, Hardware Insert Delay = 5.13ms
88.2kHz: MTRX Studio: AD -> DA, Hardware Insert Delay = 0.62ms
88.2kHz: MTRX Studio: ADAT -> ADAT, Hardware Insert Delay = 0.09ms
88.2kHz: MTRX Studio: Dante -> Dante, Hardware Insert Delay = 0.08ms
88.2kHz: MTRX Studio: Dante -> AVIO (AES) -> Dante, Hardware Insert Delay = 3.68ms
96kHz: MTRX Studio: AD -> DA, Hardware Insert Delay = 0.57ms
96kHz: MTRX Studio: ADAT -> ADAT, Hardware Insert Delay = 0.08ms
96kHz: MTRX Studio: Dante -> Dante, Hardware Insert Delay = 0.07ms
96kHz: MTRX Studio: Dante -> AVIO (AES) -> Dante, Hardware Insert Delay = 3.6ms
Ferrofish Pulse 16 for analog expansion via ADAT -> DA + DA -> ADAT
44.1kHz: MTRX Studio: ADAT AD DA, Hardware Insert Delay = 0.75ms
48kHz: MTRX Studio: ADAT AD DA, Hardware Insert Delay = 0.70ms
88.2kHz: MTRX Studio: ADAT AD DA, Hardware Insert Delay = 0.37ms
96kHz: MTRX Studio: ADAT AD DA, Hardware Insert Delay = 0.34ms
96kHz: MTRX Studio Dante -> MTRX Dante -> MTRX Studio = 2.18ms
96kHz: MTRX ST -> MTRX -> DA AD -> MTRX ST = 2.75ms
The last 2 here are somewhat experimental but show how to patch in an analog compressor connected to MTRX in another room uplinked via Dante.
[MTRX]
44.1kHz: MTRX: AD -> DA, Hardware Insert Delay = 1.15ms
44.1kHz: MTRX: MADI -> MADI, Hardware Insert Delay = 0.16ms
44.1kHz: MTRX: Dante -> Dante, Hardware Insert Delay = 0.23ms
44.1kHz: MTRX: AES -> AES, Hardware Insert Delay = 0.13ms
48kHz: MTRX: AD -> DA, Hardware Insert Delay = 1.00ms
48kHz: MTRX: MADI -> MADI, Hardware Insert Delay = 0.14ms
48kHz: MTRX: Dante -> Dante, Hardware Insert Delay = 0.23ms
48kHz: MTRX: AES -> AES, Hardware Insert Delay = 0.13ms
88.2kHz: MTRX: AD -> DA, Hardware Insert Delay = 0.56ms
88.2kHz: MTRX: MADI -> MADI, Hardware Insert Delay = 0.08ms
88.2kHz: MTRX: Dante -> Dante, Hardware Insert Delay = 0.11ms
88.2kHz: MTRX: AES -> AES, Hardware Insert Delay = 0.06ms
96kHz: MTRX: AD -> DA, Hardware Insert Delay = 0.51ms
96kHz: MTRX: MADI -> MADI, Hardware Insert Delay = 0.07ms
96kHz: MTRX: Dante -> Dante, Hardware Insert Delay = 0.10ms
96kHz: MTRX: AES -> AES, Hardware Insert Delay = 0.05ms
48kHz: MTRX: AES -> PCM96 -> AES, Hardware Insert Delay = 1.28ms
96kHz: MTRX: AES -> PCM96 -> AES, Hardware Insert Delay = 1.11ms
Jeff
Jeff Komar
Solutions Specialist, Pro Audio
S6 FAQ
Old 01-02-2021, 03:19 PM
megatracks's Avatar
megatracks megatracks is offline
Default Re: MTRX IO Delays
Jeff!!! This is awesome. Thank you so much!!!
Avid S6M40-32-5D, MTRX (2), Barefoot MM26, PT Ultimate HDX3, CB TMC1 S6 Penta
Old 01-02-2021, 04:32 PM
Do these apply both to the MTRX and MTRX Studio?
Old 01-02-2021, 04:34 PM
These are MTRX Studio only. I'm going to fill in the other rates and repeat the drill for the flagship MTRX as well. Stay tuned.
Jeff
Jeff Komar
S6 FAQ
Old 01-02-2021, 05:54 PM
thesoftcentre thesoftcentre is offline
Worthy of stickie status
Many thanks
Old 01-03-2021, 10:15 AM
Many thanks
Agreed on both points!
Thanks for this Jeff!
Scott Gatteño
Old 01-04-2021, 03:34 AM
uptheoctave uptheoctave is offline
Thanks for this Jeff.
It would be very, very helpful for this to be automatically calculated, or for there to be a roundtrip 'ping' type plugin (like the IO plugin in Logic) to save a lot of faffing about.
James Richmond
http://www.uptheoctave.com
Audio Production Reviews and Technique
Latest article for Pro Tools Expert:
"DAD Monitor Operating Module review"
https://bit.ly/30HGqPv
Old 01-04-2021, 09:33 AM
gives's Avatar
gives gives is offline
Good idea!
G
Gregory Ives, Composer/Sound Designer/Musician
http://www.gregives.com
https://pro-labs.imdb.com/name/nm1170521/?ref_=sch_int
Protools 2020.12 Ultimate HD Native Thunderbolt Avid HD IO
Mac Pro 3.5GHz 6-Core Intel Xeon E5 64GB of Ram
OSX Mojave 10.14.6, Digital Performer 9.5.2, Logic Pro X 10.5.1
Old 01-30-2021, 03:39 PM
IrelandM IrelandM is offline
To keep updated.
Regards
Old 01-30-2021, 03:40 PM
Originally Posted by IrelandM View Post
To keep updated.
Regards
You can hit Thread Tools -> Subscribe, rather than posting.
MTRX-> HDX or MTRX->Dante ArmyofLight Pro Tools HDX & HD Native Systems (Mac) 31 04-22-2020 04:35 PM
FS: MTRX 2x 8 Line Input Pristine Card 1x MTRX SPQ Card antonis Buy & Sell 9 04-11-2020 07:47 AM
Where are all the delays?! Southsidemusic Pro Tools 11 27 01-14-2014 07:36 AM
Help with Tap Delays soundbobby VENUE Live Sound Systems 2 04-01-2010 04:28 PM
WHY DELAYS ? EejayDray 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-17-2005 04:05 PM
