Hi everyone, I'm having trouble with PT's meters. They're not showing red or clips anymore and it's very deceiving. I don't know what's going on, how can anyone mix this way?
I've tried changing to all type of meters and they all behave the same way (even the PT Classic). Even if I put the Master fader all the way up. Distortion is obvious, you can hear it but I can't see it. What's up with that? Thanks in advance! |
I think it works for most people! I've got nothing useful to add except to say that you should have clip warning on steroids - the name of the track in the tracks list also turns red when the track meter shows a clip.
2010 iMac 4gig ram, OS 10.8.5, PT12.4, Saffire Pro 40, Octopre. 2011 Macbook Pro 4gig, OS 10.10.4, PT12.4, Fast Track |
Two different set ups at different studios behave like this. I thought that it was something that PT 12 implemented with it's new meters or something like that.
You should have yellow clip lights on all tracks but the master.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
I've seen this happen as well. It seems in the Edit window the meters won't show a red/clip, but they do in the Mix window.
I just assumed this was a bug, like the 10 million other things that have been present with 12HD... |
Are you running the session at 32 bit float? I'm not for certain on this one, but I think that increases your headroom inside of the DAW a staggering amount. If so, the distortion from clipping that you're hearing is in your converters themselves and not in Pro Tools, which may be your issue. Again though, I'm just guessing. Anyone have anything to add to this postulation?
Pro Tools 2020.5 2018 i7 Mac Mini 32 GB RAM "Great things are done by a series of small things brought together." -Vincent Van Gogh |
PT internal mixer operates with floating point math regardless of session settings. Internal audio can exceed 0 dBFS without adverse effects as long as it is attenuated down below 0 dBFS before it gets sent out to a file or to a converter. Once you hit that master fader, you can actually clip.
Clip lights up in both my Edit and Mix windows. The track name also turns red in the Tracks list (edit and mix windows).
![]() Quote:
Thank you for clearing that up for me. Best of luck to the OP!
![]() Quote:
Best regards. |
showing parent clip group of offline-clips | Frank Kruse | Post - Surround - Video | 2 | 04-14-2015 09:53 AM |
edit window not showing clip on a meters | dmitri85 | Pro Tools 11 | 9 | 10-25-2014 04:03 PM |
Meters showing inaudible sound when record enabling input 1 on the mbox 2 mini | jt1432 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-15-2013 07:37 PM |
no audio or meters showing on playback | P,B,S | Pro Tools 11 | 0 | 06-25-2013 06:45 AM |
XMON central meter section not showing meters | tonmeistermat | ICON & C|24 | 2 | 11-15-2006 05:38 AM |
