Old 03-23-2012, 05:20 PM
rivetheadsound rivetheadsound is offline
Default Sc48 and pt10 32 channels
So I'm trying to get the 32 channel count going with my sc48. I have v3 software and a demo license of pt10. I did the software and firmware update...and the board now shows 32 FireWire channels...but pt only show the 18. Am I missing something? Could it be because I'm only running pt 10.0 not 10.1 (which I think is the newest). I'm open for suggestions.
Brian Lloyd
FOH Engineer - In The Mood LIVE
-Reality.exe corrupt. Reboot?-
Venue SC48
Macbook 13"
HP 2525TX Tablet
Motion Tablet LE1600
Mac Mini 2.6 dual core with 1TB 4gig Ram
Old 03-23-2012, 09:41 PM
dstagl dstagl is offline
Default Re: Sc48 and pt10 32 channels
Did you install the FWx driver for ProTools?
Dave
David Stagl - Mixer | FOH Engineer
http://www.staglproductions.com
http://www.goingto11.com
Old 03-23-2012, 11:01 PM
yes i downloaded and installed the newest 002&003 family drivers
like i said....the board lets me do the 32 channels...and i did the firmware upgrade on my mac. but when i do the venue link option when creating a project, it only goes to 18...and so does the bus options in protools.
Brian Lloyd
Venue SC48
Macbook 13"
HP 2525TX Tablet
Old 03-24-2012, 03:43 AM
digidesigner digidesigner is offline
No, you need the FWx32 driver for PT, not the 003 driver, clean uninstall everything, install PT and FWx32
Old 03-24-2012, 03:50 AM
FWx32 and firmware update link
Old 03-24-2012, 03:57 AM
While we are at it, I'll let you know a way for a workaround if you end up having issues with FWx card firmware updater. I had some problems with that. When trying to run the updater for the SC48 FW card, I instantly got a message of Firmware being up to date, even though it obviously was not (19-32 channels grayed out). So I finally had an idea of opening Pro Tools up and THEN running the firmware updater (my FWx32 driver for PT was already installed). So then when PT was running I was finally able to successfully run the Firmware updater for FWx card as well and now everything is cool. Will try to downgrade to PT9 to see if I can make it work too, Robb has said to my colleague at Frankfurt Music messe that PT9 should work too.
Old 03-24-2012, 06:05 AM
Done uninstalling 10 and installing PT9, updating to 9.0.6.
I'm glad to inform, that PT9 will work with FWx32 and VENUE, giving you 32 channel IO, thank you Avid, for not killing it for PT9!
Old 03-24-2012, 07:25 AM
Tigerspill Tigerspill is offline
Good to know it works for PT9!
Others had posted that this was not an option and that PT10 was required.
Coule someone from Avid maybe comment on whether this is this an official (and supported) combination - Venue 3 with PT9 and the FWx32?
Old 03-24-2012, 11:55 AM
ok..so now I'm back to 9.0.6
and protools shows the venue as the new FW32 interface...but says that there is no connected device. and i need to change input names. the venue is selected as the playback engine too
Brian Lloyd
Venue SC48
Macbook 13"
HP 2525TX Tablet
Old 03-24-2012, 01:11 PM
Hmm, I'm not sure what you mean, if PT would not see the VENUE desk, it would not offer you the FWx32 driver under Playback Engine. So if you can choose FWx, how come it says there is no connected device!?
SC48 + Aviom A360 Mixers: Drum Channels Dropping Out justinphilip VENUE Live Sound Systems 3 02-04-2014 05:52 PM
SC48 to PT10 to Mackie Onyx 1640i Luis Marin VENUE Live Sound Systems 4 03-08-2013 05:30 AM
PT10.0.1/Venue SC48 Al Rettich macOS 0 05-07-2012 02:24 PM
64 channels with the SC48 united VENUE Live Sound Systems 2 04-03-2012 07:11 PM
SC48 = 32 Channels of Recording . . ? morrison.ece05 VENUE Live Sound Systems 12 09-12-2011 11:40 PM
