  #21
Old 10-07-2015, 09:46 AM
Default Re: 12.2.1 Automation Improvements
Originally Posted by Frank Kruse View Post
In my case I'd say I use that as a feature in 0.000000000001% of all clicks on the write to button.
For my workflow, it's exactly the opposite: Trim mode, find new balance, hit "write to all" on the control surface. If you guys are suggesting that write-to-all behavior require more clicks (selecting entire timeline), or be removed, I'd scream loudly against.
I realize that the "write to select" behavior needs work, and indeed it should be improved, but not at the expense of a more difficult write to all process.
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.12.6, PT 2018 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24.
  #22
Old 10-07-2015, 12:13 PM
made made is offline
Frank:
I think the way they made it (can't check. Don't have 12) is that you only get warned when you made a selection while playing and then hitting write to selection while still playing. They did this to keep the write to all feature when no selection is made in stop.
That's what I tried to check. Here on 12.2.1 there is no difference to previous versions...
i7 3,39GHz, 32GB, PTHD2018.12, OS 10.12.6, S3, Transport, (EuCon 19.5.1.44)
LIO
AJA XT-Express
Reaper 5.97, Fireface UCX
MacbookPro i7 PTHD2018.12 10.12.6
  #23
Old 10-09-2015, 01:27 AM
Danny Caccavo Danny Caccavo is offline
That's exactly why it was written that way.
When Pro Tools is running and you make a selection, it is only an Edit selection, not a Timeline selection. Automation works on Timeline Selections only.
So the "gotcha" this was fixing was only when you had "Suppress 'Write To' Warnings" checked, if you made a selection while the transport was running, and hit "write to all/selection," expecting it to write only to the selection.
There are a lot of people who don't want to be warned every time they do an intentional "write to all" (with no selection).
Actually pressing the "Write To All" button accidentally if there's no selection of any kind? That is not what this feature was designed to do. If you're afraid of that happening, you should not be checking "Suppress Automation 'Write To" warnings at all.
  #24
Old 10-09-2015, 01:32 AM
Thing is: They call that button "write to selection" not "write to all" (see screen shot above).
PTHDn 2019.10 (OSX10.14.6), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM
  #25
Old 10-09-2015, 01:41 AM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
I am totally with Frank. It is clumsy implementation. Oh you don't want that? Have a nag screen. .....er no thanks. This is lethal in post. Make it an optionr or a pref or two buttons. It's like the N key, does two things that I can't separate The argument that many people want different things is just lame as it ultimately shows Avid find it easier to sit in committees and shrug at its users variance. Get Agile Avid and do something useful. It's just programming, not wheel re-invention!,
cheers
Mike Aiton BSc (hons)
Dubbing Mixer/Sound Designer
BAFTA member
IPS member
former Post Production Expert at www.pro-tools-expert.com
www.mikerophonics.com
  #26
Old 10-09-2015, 02:29 AM
... so anyone using 12.2.1?
anyone experiencing new behaviour in terms of "Write to Selection" (or "write to all" as some call it)
I'm just wondering if there is something wrong with my system or Avid forgot to add "coming soon..."
thanks!
LIO
AJA XT-Express
  #27
Old 10-09-2015, 04:19 AM
I have shot a quick video demo - how do I host it?
it works as advertised - which is far from ideal. A small improvement...but not good enough, more homework required Avid
cheers
BAFTA member
IPS member
  #28
Old 10-09-2015, 05:54 AM
so there should be a message or something that should tell you "hey, you've just messed up your session!"
I guess I have to delete my preferences etc...
thanks for checking!
LIO
AJA XT-Express
  #29
Old 10-09-2015, 07:54 AM
here's the video - sorry about the resolution - was in a hurry
PT 12.2.1 HDX
Automation warnings in PT 12_2_1 by mike.aiton, on Flickr
cheers
BAFTA member
IPS member
  #30
Old 10-09-2015, 07:57 AM
Postman Postman is offline
I don't understand Avid's logic here. Automation commands including Write To Current and Write To All Enabled work "on the fly" with Edit selections, whether during playback or otherwise. That fact that they do is one of my favorite features. Why are some restricted and others not?
You've labeled the command in question as "Write Automation to Selection" in Pro Tools and S6 shortcut key is labeled "Write to All Sel". Insisting that NO selection is the same as ALL selected is contrary to the naming, contrary to the automation behaviors elsewhere in PT, and counter intuitive. If you want to put in a preference that allows different users such as Rich and Frank to make their personal choice, that would help a lot. Otherwise, please CHANGE the current behavior to make it less dangerous to hours/days/weeks of work.
HTML code is On
Improvements fsb1 Artist Series 0 09-25-2010 09:15 AM
Rtas improvements in PT 8? grandcoolee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-17-2008 11:15 AM
Pro tools needs some Improvements Xbuk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 03-19-2005 05:52 PM
Possible improvements to the DUC? AVGuru1 General Discussion 0 01-21-2005 01:20 PM
Digi001 NEEDS IMPROVEMENTS! mixermon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 42 10-25-2001 01:51 AM
