Old 04-30-2015, 09:36 PM
mmoeding mmoeding is offline
Default HD Omni turning on but has no display
Hey guys,
About 2 hours into my work day, I tried adjusting the monitor volume on the omni and noticed that it was stuck and not changing. I then realized that none of the buttons were doing anything and it seemed frozen. I then powered down the unit and turned it back on to find no display at all. I restarted everything and powered on again without Pro Tools open and the power light switched from orange to green right away but still no display on the unit (usually the power light stays orange until pro tools is launched). Pro tools starts fine, so its still recognizing the unit, but nw I can't get any sound out and the display is dead. I tried switching power cables and even running on a different circuit and one time I turned it on and it the display came back but then when I power cycled once more the problem came back. Did this thing really just die on me? I've only had it for a couple years.
Old 05-01-2015, 10:28 AM
Default Re: HD Omni turning on but has no display
If its out of warranty, I would pop the top cover and reseat any connections feeding the front panel. Its likely a long and narrow PCB behind the panel and may have more than 1 connection. Maybe one has come loose, or maybe you're in a damp environment and its making pins and sockets oxidize
Old 09-05-2015, 01:20 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Did you ever find a solution? Mine did the same EXACT thing, out of nowhere, today.
-Ryan Young
•Pro Tools 12.6 (x2)
•OSX 10.11 & 10.12
•Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon (x2)
•16 GB 1333 MHz DDR3 (x2)
•HD Native PCIe (x2)
•HD Omni (x2)
•192 i/o
•96 i/o
•4 Seagate Barracuda 1.5TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
•Blackmagic Intensity Pro (HDMI)
Old 09-06-2015, 12:33 AM
JFreak's Avatar
JFreak JFreak is online now
Guys, there is a know issue of backlight going down so please check it first.
So turn off the room lighting and take a very close look at the LCD panel. You should be able to see "something" happening there. If so, then there is a user setting for the backlight but I don't have OMNI so I don't know the button combination how to get there. Someone else will help you if this is the case.
Janne
Old 09-06-2015, 12:38 PM
Shan's Avatar
Shan Shan is offline
A similar issue happened to my HD OMNI a few years back. You'll need to change the contrast of the display and then reset the unit. Turn the unit on then press SETUP, then rotate the PUSH CR/HP knob clockwise 14 indents, press the PUSH CR/HP knob and then rotate it until you can read the display again. Once you can read the display again, you can do the procedure to reset the unit: SETUP > rotate the PUSH CR/HP knob to RESET(13 indents) > press the PUSH CR/HP knob and select "SURE?". As a side note, you can shine a flashlight into the display to help read it when you change the contrast back. The contrast default is 20.
Keep me posted if this worked out for you.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 11-10-2018, 11:22 AM
Dan Gralick Dan Gralick is offline
Shane
Thank you! Have no idea why my contrast just decided to change, but Shane nailed it. Back to work!!!
Old 12-13-2018, 02:10 PM
tom_lowe tom_lowe is offline
Shane
Thanks so much! just randomly had the same thing happen!
turning off "External" monitor on OMNI Tim R. Pro Tools HDX & HD Native Systems (Mac) 2 06-25-2013 08:10 PM
OMNI Fried? Calling Omni Members - Check High Samplerates KingFish Pro Tools TDM Systems (Mac) 3 11-03-2011 10:19 PM
Be aware! Potential HD Omni buyers with treated Rooms and Computers. Omni Noisy Fan FRaNCo MuSiC Pro Tools HDX & HD Native Systems (Win) 0 09-25-2011 06:42 AM
Guitar Center now has HD Omni on display nst7 Pro Tools TDM Systems (Mac) 0 08-24-2011 01:58 PM
turning off cinema display? Alan LaFleur Pro Tools TDM Systems (Mac) 3 07-16-2002 10:13 PM
