Old 11-22-2009, 09:55 AM
DigiNdee DigiNdee is offline
Default My Virtual Instruments have disappeared
Hello DUC folks,
My virtual instruments (Omnisphere, Trilian, Italian Grand) have disappeared from the Instruments list. They were showing recently but now when I open a new instrument track and look in the list they're gone (only the PT VI are there).
I recently updated from PT8 to 8.0.1 so the problem might originate from there (?)
I've search the forum here but could not find anything related. Any idea on what I should do?
Music XPC C6X,Core 2 quad, 4 Gb RAM, XP Pro SP2, PT 801, Mbox2.
I'm stuck now and can't work on my project so any help would be appreciated.
Thanks,
DigiNdee
Old 11-23-2009, 04:36 PM
Kirby B. Kirby B. is offline
Default Re: My Virtual Instruments have disappeared
I would reinstall the VIs without uninstalling them first. Actually before that I would make an image with True Image or Ghost or at least Windows System Restore. I would also upgrade to SP3 for your XP. Never know.
Digi002R PT2018 Win 10
INTEL Core i7 930, 3.52 Ghz
GIGABYTE GA-X58A-UD3R
CORSAIR XMS3 12GB 1600Mhz
2 X WD 1TB Caviar Black 64 GB cache
MOTU Traveller PT2018
MacBook Pro Mojave
16GB DDR3
Old 11-23-2009, 04:53 PM
sbag sbag is offline
I would check in common files> digidesign > unused plug in folder on your system drive
Gear>
C8, 002, Trigger Finger, Kontrol 49, Apc 40
SW >
Pt 8, Reason 5, Recycle 2.1, Ableton Live Suite 8.02
Plugs >
All Registered plug in's & Vinyl out the wazoo. Mp3 sucks
Old 11-23-2009, 05:01 PM
+1. That would be the easiest fix.
MacBook Pro Mojave
16GB DDR3
Old 11-29-2009, 07:07 PM
Hi, thanks for the reply.
My Plugins don't show up in the unused plugins folder however they show up in the plugins folder but are not available in PT (they were before the 801 update).
Take note that I have Sonar installed on the same computer and my plugins are available in VST in Sonar and they work fine. However, since I updated from PT LE 8 to 801 my plugins have disappeared from Pro Tools (but are showing and working in Sonar as stated).
Has anyone experience this after the PT LE 801 update?
What should I do next?
Thanks.
DigiNdee
Old 11-29-2009, 07:54 PM
cwsand's Avatar
cwsand cwsand is offline
Try trashing preferences and database files.
Help Us Help You
Chris
__________________________________________________
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4
macOS High Sierra Version 10.13.6
Pro Tools HD 2019.10
Old 11-30-2009, 06:24 PM
Thanks for the help, however, can you provide more information on where to go and what to do in order to "trash preferences and database files"???
DigiNdee
Old 11-30-2009, 06:57 PM
scar97 scar97 is offline
Originally Posted by DigiNdee View Post
DigiNdee
TAMARA on how to do that unless you look at the general troubleshooting on the main page.
Here is a question. Did you clone your drive or have you changed out your hard drive recently?
"It aint about the stuff you got..If it sounds right you're finished..Burn it!"
For all complaints click here
DAW
Digi003 PC-Sweetwater CS dual 3.0/Asus 975X Chipset/CPU dual 3.0GHz/800MHz FSB/RAM 4GB/Radeonx300se/4 internal glyph sata drives/ 3 external glyph backup drives/Acronis True Image OUTBOARD-UA LA-610, ADL-600, Digimax lt, Eureka x 2, Central Station, Hearback x 8, JBL LSR, Monster Power Software-PTLE 8.0, Sound Forge, CD Architect Plugins- Too many and too much money spent
Old 12-02-2009, 08:04 PM
cwsand's Avatar
Ok, what's with TAMARA? Is that like FUBAR or something??
Help Us Help You
Chris
PreSonus Digimax LT
Old 12-02-2009, 11:47 PM
http://duc.digidesign.com/showthread...ghlight=tamara
Just some lite humor from Keybeeeets but many new people post on the forum asking the same questions over and over again while the answer is right on the first page under general troubleshooting.
I had to ask once as well.
He could look under the post and it would tell him in clear detail how to trash his prefs and databases and there is even a digi utility to do it for him.
DAW
Virtual Instruments rich7707 Pro Tools 10 1 03-07-2013 07:17 PM
No virtual instruments gilaltom3 Windows 0 07-27-2012 07:18 PM
someone can help me buy some virtual instruments? abn2012 Virtual Instruments 0 07-17-2012 06:18 PM
Virtual instruments Gylen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-25-2003 02:03 PM
Virtual instruments etc gmcgmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 02-26-2003 01:51 AM
