Old 09-08-2009, 01:31 AM
USBnoGood USBnoGood is offline
Default Why is Time Shift so horrible?
One of the first things I do after deleting preferences is to change the default Time stretching plug in to the old TCE.
It has artifacts, but it's a lot smoother! Time Shift always leaves horrible clicks and weird pitch changing effects. I haven't found one application where Time Shift was better to use for quick audio region stretching...
Who agrees/disagrees with me?
Hardware:
MacBook Pro 2.16 GHz Core 2 Duo (4 GB RAM inst./3 GB used, new 320 GB/7200 RPM HD) , Digi 003 Rack, Apogee Mini-Me, 2 FW400 Oxford 911 enclosures;
Software/Plugins:
- Mac OS X 10.5.8, Pro Tools LE 8.0.1;
- Addictive Drums 1.1.0, POD Farm, Kontakt 3.5, Melodyne Plugin, Sonalksis (All), T-Racks 3 Deluxe;
Issues:
Random errors of Lost Communication, invalid clock and RTAS CPU (even below 25% usage).
D-Verb 2.0 test:
About 55 (11 tracks) at 1024.
Old 09-08-2009, 04:27 AM
chrisdee's Avatar
chrisdee chrisdee is offline
Default Re: Why is Time Shift so horrible?
I think elastic audio is supposed to be better for that. Have you tried it ?
Old 09-08-2009, 05:40 AM
Oddbod Oddbod is offline
I agree Time Shift does not produce great results for me. I saw a very good tutorial on Elastic Audio and get much better results than Time Shift.
O-B
Old 09-08-2009, 09:47 AM
daeron80 daeron80 is offline
Time Shift takes a little more getting used to, but it can be great on certain things when the settings are appropriate to the material. Does a great job on voice if you take the time to experiment with mode and range, and don't try to push it too far. +/- 3 semitones is about the limit unless you can put up with noticeable artifacts. The source material must be fairly clean, too. If you've got lots of room tone, RFI, or hum, forget it.
I use it in fixing old spoken word material where sometimes the speaker says the wrong thing - like gets a name wrong or something, and I need to find the right one elsewhere and pop it in. Usually needs a bit of EQ and pitch shift to fit well. Time Shift is brilliant for that. The old Pitch Shift plugin doesn't work for that at all because it shifts the formant with the pitch.
David J. Finnamore
Nyquist was right.
PT 2019.10 Ultimate | Omni | macOS Sierra
PT 2019.10 | Saffire Pro 40 | Win10
Old 09-08-2009, 10:16 AM
allstaar's Avatar
allstaar allstaar is offline
With regards to those clicks, make sure you have the latest version of Time Shift. There was a problem with an earlier release.
Old 09-08-2009, 10:33 AM
I doubt it's an "earlier release"... I have Pro Tools 8.0.1
Hardware:
Software/Plugins:
Issues:
D-Verb 2.0 test:
Old 09-08-2009, 11:49 AM
allstaar's Avatar
Ahh yes, didn't read your sig unfortunately.
By the way the x-form option in elastic audio consistently out performs the other available algos in Protools for me.
Old 09-11-2009, 05:23 PM
guitates guitates is offline
Oddbod -
Where can I see this Video ???
Thanx
I Seek the Holy Light...
Isaiah 40:31
72 Strat with single 2-Blade pickup
PTLE 10.3 LE
2-SSL Alpha Channels - 1 SSL G-Compressor
Apogee Rosetta 200 - Z-Systems Opti-patch
Lexicon MPX-G2 Guitar Processor - .003r
Command 8 - Roland JV1000 + Triton Rack
FOCAL TWIN 3way speakers + JBL Q108MK11 Bottom
2-52 jax MilSpeck Patch Bays
2-22" Apple Cinema Display's
Allen & Heath 16ch Mixr
**Currently = 11-1-12
2 CD's Released-1-2003-2-2012 Worship ROCK
BIG BUG: Wrong playlist calculations when using AS Pitch 'n Time or Avid Time Shift Franco1967 Pro Tools 11 1 01-25-2014 12:31 PM
I am having the most horrible time trying to install pt9 -Davo Pro Tools 9 7 11-08-2010 10:31 PM
PT8 - Pitch 'n Time LE and Time Shift - very slow to operate Richard901 General Discussion 3 12-30-2008 10:00 PM
Explanation for FORMANT shift in Time Shift Plug In, please! Darney 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-13-2007 12:00 PM
Time Shift: Why no pitch/time strap?! EricWillhelm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 09-17-2006 06:44 PM
