Old 11-03-2005, 09:52 AM
mrgummy mrgummy is offline
Default File recovery
Using win xp pro, LE 6.4. I create session, save to external drive. then I take drive to 2nd pc running LE 6.4 and some tracks are missing. Appears that some randomly save to c drive on my pc. What gives??
Old 11-03-2005, 12:07 PM
DigiTechSupt's Avatar
Default Re: File recovery
Do you possibly have 'Round Robin' recording enabled in the Disk Allocation window?
Avid Audio Tech Support
Support FAQ
Old 11-03-2005, 12:14 PM
Kris75's Avatar
Kris75 Kris75 is offline
Space Cabin Audio
I have this same problem, but only when usisng a template. It never happened it 5.3 though. Always check your file path. 6.4 will not always default to the session file.(On my system anyways)
And no, round robin is not turned on.
Hope this helps
Sign up for all things....AWESOME!
Kris
May the music move you
Old 11-03-2005, 12:27 PM
Never copy files using Windows Explorer... open the session and use File->Save Session Copy In...
This will ensure that the disk allocation is reset correctly.
Kris, your issue is a Mac OS X issue... search the DUC for template for workarounds.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 11-03-2005, 01:23 PM
Kris75's Avatar
Space Cabin Audio
Thank you for your reply Rail. So this is a osx issue. I now understand why my friends with macs have the same problem. thank you again. I will search for template workarounds.
You are the man.
Kris
file recovery keny Pro Tools TDM Systems (Mac) 2 08-05-2009 12:41 AM
Drive recovery or file recovery bobmaus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-13-2006 04:00 PM
File recovery for PT 7?? poppy Pro Tools TDM Systems (Mac) 1 05-26-2005 01:44 PM
PTS File Recovery RuckusEnt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-26-2003 06:22 AM
Best File Recovery Prgrm for OS9? pontuso Pro Tools TDM Systems (Mac) 1 05-20-2003 01:48 AM
