Old 10-13-2019, 02:18 PM
Downtown_BE Downtown_BE is offline
Default iLok Cloud
I´m currently running all my licenses from an ilok - I´m travelling a lot with my rig always in fear of loosing my ilok so I was wondering if I can:
- use all my licenses from ilok cloud
- do I ALWAYS have to be online and what happens if I´m offline on a flight? does protools (ilok) let me use them for an hour offline or not?
THX!
Old 10-13-2019, 02:37 PM
Default Re: Ilok Cloud
Yes you need to be connected pretty much continuously to the Internet if you want to use cloud licensing
No you don't if you have an iLok... one of the main benefits of the iLok (although iLok ZDT, if you want to use that does need to see your iLok connected infrequently, and you will have ZDT if you are worried about loss...)
Your licenses are either in the cloud or on the iLok they cannot be both, so you can't use an iLok to make up or being disconnected from the Cloud fro some period of time.
Old 11-12-2019, 04:15 AM
Default Re: iLok Cloud
ok weird thing is I'm getting the message "license can only be activated to ilok" when I start up protools...
Old 11-12-2019, 05:04 AM
iLok.com only needs to see the iLok from time to time IF you're using the free TLC (theft and loss) coverage. As far as ZDT - it's worth the few bucks one pays for it as is having a spare iLok.
When PT puts up the error are you running from your physical iLok? What does the ILM s/w tell you as to where your PT license asset is?
Old 11-12-2019, 07:56 AM
Also be aware that there's loads of plugins that aren't capable of cloud authorization.
As Darryl mentioned, if you have an iLok you should definitely have ZTD/TLC and a spare iLok; if you lose it or break it or forget it you can be up and running in a half hour.
Clloud authorization for Pro Tools is not great; I've been on sessions that ground completely to a halt and had to be scrubbed because the internet went out.
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.12.6, PT 2018 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24.
Old 11-12-2019, 11:20 AM
Benoni's Avatar
Benoni Benoni is offline
I have a full video of all the possible scenarios when using iLok Cloud here
iLOK CLOUD | IN DEPTH
https://youtu.be/NKZINYC7W_0
Since the video they have introduces a couple new features called Automatic Mode and Managed Mode which you can read about here
https://ilok-com.s3.amazonaws.com/iLokCloud.pdf
Keep in mind, not all iLok licenses are cloud enabled.
Old 11-13-2019, 12:21 AM
great I´ll check that
Old 11-13-2019, 09:38 AM
SomeOtherGuy SomeOtherGuy is offline
Exactly, which is why virtually no one can use it to avoid having to carry a physical iLok. And to boot, if you want to use machine authorization as an alternative, there are many plug-ins that don't support that either.
Pro Tools Ultimate, Avid MTRX, MOM, Mac Pro 3.5 Ghz 6-Core (2014) 64 GB RAM, Mac OS Mojave, Samsung T5 SSDs
Old 11-14-2019, 04:00 PM
jscomposer jscomposer is offline
Devil's advocate...
Should a modern studio be expected to maintain internet access like it maintains everything else?
Most allow authorizing to your machine. Only plugin I've bought over the years that requires a physical iLok is Slate's Trigger 2. And I'm considering selling it because of that.
Old 11-15-2019, 10:10 AM
Ah, wish that were true. So many don't support machine authorization:
Sonnox, Altiverb, Autotune, Izotope, Melodyne, Pitch'n Time, Seventh Heaven, etc., to name a bunch.
New iLok License Manager Released - Now Supports iLok Cloud Managed Mode unkJE Licensing & Accounts 0 10-10-2019 05:07 PM
Moving licenses from iLok Cloud to iLok USB Key Stratus Licensing & Accounts 2 03-15-2019 10:53 AM
Unable to move ilok licenses from cloud to ilok. Charu1 Pro Tools 2018 14 03-01-2019 09:05 AM
iLok Cloud and other physical iLok mik Pro Tools 2018 2 05-04-2018 10:51 AM
