Keyboard shortcut to close active plug-in window?
There is this little 'plug in' button on the 003 I use at my workplace, it opens and/or closes the selected plug-in's window. I find I use that button a lot.
Since I don't have the 003 at home I was wondering if there is an equivalent keyboard shortcut I could use. I've been digging thru the threads here and found CMD+OPTION+W but that only closes all plug-in windows. Couldn't find anything like that in the Scripts thread either. Even Google failed me as a friend here, maybe one of the PT Power Users here has a clue..?
"Don't look; listen!" At work; 2013 27" iMac/i5/2.9GHz/8GB, OSX 10.8.5, PT 10.3.6 At home; Custom Made Mac (Hackintosh) i7 (3770 "Ivy Bridge")/3.4GHz/32GB@2400MHz, Samsung SSD 840 EVO 250GB System Drive, Samsung SSD 750 EVO 250GB Audio Drive, OSX 10.10.5, PT 12.8.1 |
Re: Keyboard shortcut to close active plug-in window?
Not that I know of. You can close AND reopen floating windows with Ctrl+Option+Cmd+W.
Thanks Stig, not quite what I was looking for but a useful shortcut to know just the same.
Opening the currently selected plug-in will probably never work as a classic shortcut but for a console or EUCon remote application only. |
Thanks for your reply Oliver. It would appear you are right. I've asked some of my more experienced PT-friends (outside of this venerable forum) and they either were as clueless as I am or pointed out the same issue you mentioned.
You are welcome, I wish someone would have better news for you.
Shortcut for close plugin window | José Luis Díaz | Tips & Tricks | 11 | 02-02-2018 08:06 AM |
Keyboard shortcut to close the AudioSuite Window? | dversion | Pro Tools TDM Systems (Mac) | 2 | 10-16-2005 08:27 PM |
keyboard shortcut to close plugin window? | ratter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 11-29-2004 07:37 PM |
close audiosuite window shortcut? | lancebrwn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-28-2004 12:13 AM |
close audiosuite window shortcut? | lancebrwn | Pro Tools TDM Systems (Mac) | 0 | 06-27-2004 01:47 PM |
