hardware in pro tools
When using a hardware compressor in pro tools as an insert I need to send it out the same channel it is going to back in of my interface? For example, connect output 3 of my scarlett 18i20 to the input of the kt76 then the output of the kt76 into input 3 of the 18i20 then in pro tools go to the insert of the channel I want the compressor on and select io then select 3
Re: hardware in pro tools
The reason I'm asking is if that is the only way pro tools will let you use hardware as inserts and outputs for channels 1 and 2 on an interface are always used for monitors or to go to a monitor controller, how do I use inputs 1 and 2 if I obviously can't go out 1 and 2 because of monitors?
Doesn't the Scarlett have 10 line outs? Seems like you should be able set up the routing in your I/O Setup in Pro Tools so that Outs 3/4 correspond with Ins 1/2, etc.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Yes it does have 10 outs and 8 ins but I thought you had to go out the same number you're going back in. Are you saying I can set it up somehow to go out channel 3 and back in channel 1 (or any other channel) for a mono signal and if so how do I go about getting that set up? Thanks for the reply and any help you can offer!
You need to set up INSERTS in the IO setup page>Inserts tab. On that matrix(the grid and dots), you set up matched pairs of IO, like Output 6/Input 6, Output 7/Input 7. Having said that, There are 2 things you may want to consider here:
#1-using hardware inserts MAY cause latency mis-alignment(something you need to be aware of, and you may need to compensate for, manually on that same Inserts tab of IO setup) #2-this may not improve your mixes at all I am dead serious on this and have been in the exact same position as you are now. I sold my studio last year and now just operate a mix suite, but while I had that studio, it was a pretty serious setup with HD/Native and 64 IO(2x HD IO and 2x 192 IO). It also had a 96 point TT patchbay with 40 racked preamps(Midas, Focusrite, Vintech, API, Miktek, etc) and several channels of external compressors and some EQ's. I went thru all the configuration so that I could use 8 hardware inserts while mixing. I tested and compared and it all worked flawlessly. Now, guess how many times(over 3 years of commercial recording) that I used a hardware insert while mixing? Not once I used the outboard during recording a lot, but in every single case, I could find a plugin that would match or beat hardware every time, without any of the hassle of routing and latency compensation. Get things sounding good on the way in and skip hardware while mixing. The money you spend on patchbay and all the cables to go with it, will buy plenty of plugins to make great mixes. My 2 cents, but if your external hardware is anything "average"(think Warm Audio, DBX or any hardware that costs less than $1K), plugins can do a better(or at least equal) job. I spent days comparing my LA-2A clones and Pultec EQ clones and the hardware simply was no better in any way. There's not a single time when mixing needed hardware. Using these hardware boxes and comparing to stuff like the Waves Puigtec EQ, Waves CLA-2A plugins, I always was able to match or beat the hardware. Don't let your eyes fool you that something sounds better because its got real knobs The cost of the patchbay and cables topped $1K and that money would buy one of many great mics or preamps, which actually WILL make better recordings. We often THINK something is great because so and so uses it, or because some youtube video shows it. I love the new affordable hardware(KT, Warm, etc) but there are probably a dozen 1176 plugins that will match or beat your KT during a mix Spend your dollars on stuff that WILL make things better(think about acoustic treatments, a great vocal mic or a great preamp). Just an opinion
I would skip the 102. Take a look at the Miktek C7. Keb Mo tried one when he was mostly done with his last release and liked it so much that he re-recorded all the vocals with it I'm partial to the API312(or clones of it) for vocals. Just go gentle on the hardware compression. You can always add more in the mix, but if its over-cooked on the way in, it will always be over-cooked. When you mix, don't be afraid to use more than 1 compressor plugin. My vocal plugin chain is as follows:
A-empty(for Melodyne) B-EQ III 7 band(mostly just for hi-pass) C-Waves CLA-76 D-SMACK!(Avid's version of the LA-2A) E-Waves Puigtech for "air"(any Pultec-type plugin will work, Waves is my fave) F-Waves F6(only if needed) G-Waves R-DeEss(only if needed) If you do get a C7(or any multi-pattern mic), experiment with the figure 8 pattern(only if your room has proper acoustic treatments). You might be surprised
A-Autotune (if needed or wanted for t-pain type effect) B-Fabfilter Pro Q3 (for notch cuts and high pass) C-Waves CLA-76 D-Waves CLA-2A E-Fabfilter Pro Q3 (for boosting mid highs and top end air) gonna try out Waves Puigtech as you do here F-Fabfilter Pro DS I sometimes deess before compression too |
What hardware is Pro Tools MP9 looking for ? | andyman | Getting Started | 22 | 05-29-2013 10:16 AM |
Hardware for Pro Tools LE 6.7 | dekype | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-16-2007 09:01 AM |
Hardware for Pro Tools LE 6.7 | dekype | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-16-2007 08:13 AM |
Pro Tools HD 7 without hardware? | Horsepower | General Discussion | 3 | 11-17-2006 10:06 PM |
Pro Tools without hardware | aquanox | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-09-2004 04:30 PM |
