Old 07-11-2017, 01:48 AM
tendashi tendashi is offline
Default can't hear/see signal on master fader when arming audio track [solved]
i've been recording a few tracks, both audio and instrument ones, and everything seemed fine until all of a sudden there was no longer any signal coming through the master fader meter when arming or input-monitoring audio tracks.
this is both sonically and visually, although i can see levels on the track itself when feeding it.
also, any inserted plug-ins, if present, get blued-out/bypassed as soon as i arm the track.
this only occures with audio - instrument/midi works just fine.
set-up-wise hardware and playback engine is all correct and i/o seems so as well.
thanks for your help!
Old 07-11-2017, 02:29 AM
joachim's Avatar
joachim joachim is offline
Default Re: can't hear/see signal on master fader when arming audio track
You porbably have LLM (Low Latency Monitoring) enabled.
You may read the chapter "Low Latency Monitoring" in the Ref Guide, how to configure the tracks output to a physical output that is designated for LLM.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 07-11-2017, 04:38 AM
oh man, problem solved.
danke Joachim!
wieder was gelernt... :)
Old 07-11-2017, 04:56 AM
joachim's Avatar
Default Re: can't hear/see signal on master fader when arming audio track [solved]
Gut !
Track arming crash - SOLVED vieris Post - Surround - Video 0 04-19-2012 01:15 PM
Mbox 2 - Signal peaks when arming track amonmasters 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-27-2012 11:25 PM
Arming a track produces pop and no signal bootc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-12-2007 08:21 AM
hear sound without arming track?? tec 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-13-2007 08:22 PM
No Signal on Master Fader 002 during Low Latency? goom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-04-2006 10:44 PM
