solo safe
i have my background vocals going to my aux track to add reverb to them.But i can't seem to get the solo to work on any of the tracks or the aux track.I tried to solo safe the aux track but i can't solo the vocal tracks.What am i doing wrong?
Re: solo safe
Does the solo button simply not "physically" work? Or do you mean you can't hear anything when you press solo?
If the latter, check your Solo Path in I/O Setup. |
Re: solo safe
as soon as i route a channel to an stereo aux track i lose the ability to solo anything.The aux track won't solo either.I don't see anything about solo in the I/O setup.The solo button actually mutes the tracks for some reason
Re: solo safe
If you route a track to an aux, the way to solo the track is to solo safe the aux (cmd+click on a mac), then solo the desired track that is routed to that aux.
You cannot solo an aux itself alone, you'd need a VCA group for that.
iMac Pro - MacOS 10.14.6 --- - Pro Tools U HDN 2019.6 - Avid HD Omni + HD I/O 8x8x8 - C|24 | S3 | Dock |
Re: solo safe
right ,,,but for some reason it is not working that way and i can't figure why.
The solo button are acting like mute buttons |
Re: solo safe
I don't quite understand, what you are trying to do and how you do it.
You say you want to add reverb to your backing vocals, sending them to an aux. So I guess you do that by using a send. So what exactly are you trying to solo? The reverb alone?
Re: solo safe
i wanted to group my backing vocals to one track so i can control the volume with one fader and still be able to solo the seperate tracks.maybe i'm not thinking right
Re: solo safe
Okay, so you want to send the aux to another aux to add reverb, right?
Nothing wrong with that then, and it should work, like I explained earlier. If it doesn't, something's set up wrong. Can you post a screenshot of your mix window?
Re: solo safe
this is the setup i'm trying to use but nothing will solo once i route the tracks to an aux busss.Forget the effects
http://www.youtube.com/watch?v=zsN9F...eature=related |
Re: solo safe
maybe i don't have it setup right.Ill have to go in and take a look and see what i did wrong..Thanks guys
Protools 10: mute and solo aren't working. (Solo safe is not on any of the tracks.) | charlottewrinch | macOS | 2 | 04-14-2012 05:32 PM |
Solo/Solo-Safe dilemma | xcevinx | Pro Tools 9 | 10 | 12-08-2010 07:12 AM |
Solo Safe bug??? PT 8.0.1 cs | teacherman | Pro Tools TDM Systems (Mac) | 3 | 07-20-2010 09:15 AM |
what is solo safe | cyndiek | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-02-2009 11:10 PM |
"Solo Safe" problem | teacherman | Pro Tools TDM Systems (Mac) | 2 | 09-08-2006 06:48 PM |
