HD Sync I/O. No 1X Base Clock???
I cannot get either of two Sync I/O's to be set at base clock. If factory defaults are programmed, (supposed to be base clock) for some as yet undetermined reason, it reverts instantly to 256. Using the front panel menu interface, no option is given except 256. As a result the 192 I/O's do not lock (over range dialog appears) and they revert to internal clock. Everything appears to sync and play ok but I can hear very subtle artifacting on a 1 k tone.
If I plug Aardsync word clock (which is referenced to black) into the 192 I/O all these problems go away. The Sync I/O just hangs out there by itself, being referenced to black, appearing to do everything except provide clock to the 192's. Is this OK? Appearances can be very deceiving in Sync World. The sync I/O has the latest firmware update for 5.3.1. Because of a SNAFU with the feet and frames ruler in 5.3.1. Digi has told me to go back to the 5.3 app. but use all the 5.3.1 extensions. I must also use the previous version of machine control software. Is this a Sync I/O issue or the weird hybrid software config? What am I missing? What's wrong with this picture? My mix+ systems worked fine. I had my cake and I got to eat it too. |
Re: HD Sync I/O. No 1X Base Clock???
RBeggs...
Perhaps I can help you. I know for sure that you can NOT take the 256 output from AardSync into the Sync I/O and get the Sync I/O to lock (not sure if that's what you're trying to do). You MUST take the 1x out of the Aardsync and then the Sync I/O sends 256 out to the 192's. Does that help you?
The Eggman coo coo ca joob |
Thanks, but no. Aardsync is putting out 44.1 into the sync I/O. My understanding, which may be incorrect, is that the 192's use a base clock of 44.1 or 48. The legacy I/O's use the 256 freq. The Sync I/O will only put out 256 despite the manuals claims to the contrary. If I'm lucky, all will be revealed Mon.am. with a call to tech support.
J |
Curiouser and curiouser. My mentioning the Aardsync was perhaps confusing. I have decided to use it directly into the interface for now because the Sync I/O will not output any clock I can use. I want to reference the Sync I/O to black burst (video ref). It should, I believe, then output either 1X the session rate or 256 depending on what you have selected in the base clock menu. Unfortunately, I cannot select the session rate option . I can get it if I restore factory defaults. As soon as I attempt to mount a session it reverts to 256 and cannot be changed. I then receive this dialog informing me that the clock rate is out of range. When this dialog is closed the I/O's revert to internal sync mode. In other words, the 192 I/O will not accept the clock output of the Sync I/O when it is 256 and Sync I/O is incapable of generating anything else. It's almost beyond discussion at this point. Either I am doing something whack, I have missed something very fundamental or it just aint ready to do what I need to do. I appreciate your interest however. But maybe answer this. Do the 192 I/O's run at 1X or 256? Dumb question perhaps but I'm drugged by scrabbling through manuals.
The Sync I/O may not be ready for Black Burst. If you run out of the AardSync x1 output into the Sync I/O. Have the Sync I/O set for Digital input and 256 clock, are your 192's happy? Should be...
J |
Johnnyv,
Tried that one before and did it again just now at your prompt.The result is a blinking ext. sync mode LED as before. Our posts must have crossed on the net I edited my previous entry to make it more clear. Thanks |
When I buy HD IO, I got a Loop sync clock cable, can I use this one for world clock? | Rockman413 | Pro Tools HDX & HD Native Systems (Mac) | 7 | 07-07-2012 06:43 PM |
Sync Clock Help | wonderland | Pro Tools 9 | 10 | 07-09-2011 02:06 AM |
Sync HD clock v. 192 clock | WildHoney | Pro Tools TDM Systems (Mac) | 1 | 05-01-2009 11:26 PM |
Tick base & Time base for MIDI track?? | Rodamyot | Post - Surround - Video | 1 | 04-25-2005 04:57 AM |
192 I/O Internal Clock or SYNC Unit Clock? (is there a big difference?) | Mastersonics | Pro Tools TDM Systems (Mac) | 0 | 04-18-2003 07:14 AM |
