5.1 monitor controller
Hey folks!
Looking for a 5.1 monitor controller and was wondering if the S3 has that capability. I know if it has 6 outputs, but wanted to know if there's a dedicated master volume to control all the outputs. Thanks in advance! |
Re: 5.1 monitor controller
not possible...
only 2x stereo plus headphones
Mac Studio, 32GB, PTHD2022.7, OS 12.5.1, S3, Transport, (EuCon 2022.4.0.78) LIO-8 BlackmagicDesign UltraMonitor3G Reaper 6.66, Fireface UCX MacbookPro M1Pro PTHD2021.12 MacOS12.1 BlackmagicDesign UltraMonitor3G MOTU 24Ao AppleTB3toTB2->AppleTB2->Ethernet->AVB |
Thanks for the input
Anyone explain how they set up the Avid S3 for multiple monitors or will I need an external monitor controller if more that one stereo pair of monitors are added into a audio system.
Regards |
You can connect/control two pairs of monitors. Each one has a separate volume control and you can switch between the two. However, if you are on Windows, it's not possible to connect to your computer via AVB. You will therefore have to use an audio input on the S3, which means your signal will go through an A/D - D/A conversion before you can use the monitor controller. For this reason, I don't use it myself. |
To J-S-Q
Yes I own an S3. "You can connect/control two pairs of monitors. Each one has a separate volume control and you can switch between the two." I am on a Mac with no AVB but would like to control single output levels for each monitor via the S3 to the front and rear monitors can this be done any images on setting it up would be helpful. Regards |
If you press the PAGE LEFT and PAGE RIGHT buttons at the same time (they are at the top right of the S3), you will see the monitor control features displayed on the top row of knobs.
I've never actually used it myself but I presume you just connect each pair of monitors to the two stereo outs and connect a audio cables to the inputs (I believe you can have two different stereo inputs and switch between them on the S3). |
Monitor Controller Help | Josh Voyles | Avid Pro Mixing General Discussion | 2 | 09-06-2016 06:07 AM |
5.1 Monitor Controller f/s | sw rec | Buy & Sell | 0 | 07-28-2015 06:32 AM |
Can Studio Monitor Express & Transport act as digital monitor controller? | briancares | Artist Series | 1 | 02-04-2014 05:23 AM |
5.1 Monitor Controller | BroomPole | Post - Surround - Video | 6 | 04-09-2009 02:23 PM |
monitor 5.0 on a 5.1 SMPTE monitor controller? | MixerGuy | Pro Tools TDM Systems (Mac) | 1 | 07-03-2008 05:54 AM |
