Old 08-16-2012, 08:12 PM
jack s. jack s. is offline
Default What Effects Are On These Vocals?
I'm a huge Justice fan and I was curious if any of you guys can identify what vocal effects are being used on these recordings. Let me know what you can identify. Thanks in advance,
-Jack
http://www.youtube.com/watch?v=TIW1m3jbEsg
and...
http://www.youtube.com/watch?v=lqBhgEQ4LT0
Old 08-17-2012, 09:53 AM
Default Re: What Effects Are On These Vocals?
On'N'On sounds like Autotune set really hard(the old "Cher" effect) with a short plate reverb and some tight doubling, like maybe the old H3000 trick or one side at +6 cents and the other side at -6 cents. The other one sounds like a short delay that fed to the reverb enough to soften the sound of the delay(or maybe the delay is ducked by the vocal track). Probably also tuned, but not quite as hard. That's my take, but I expect others may have different ideas(that may be just as good as mine). With the technology available now, there's usually more than one way to skin a cat...er...track
Old 08-17-2012, 10:59 AM
Cool:) Thanks for the advice. I'm new to this type of music so I don't know a lot of the effects these guys use....time to experiment.
Old 10-09-2012, 09:57 PM
janmuths janmuths is offline
Load it into Tools, phase-invert one side (left OR right), then mono-sum.
Everything in the centre cancels (often voc, bass kick), everything that's on the edges of the stereo image remains (usually fx, pads, some guitars etc).
This little trick really helps to identify vocal effects.
Works much better with songs in 'proper' sound quality (CD quality or better); everything MP3 or youtube will mainly show compression artefacts.
Hope this helps.
Jan
2010 Dolphin Award for Production / Engineering
AVID Certified Instructor
Old 10-13-2012, 01:26 PM
Mixgeneral Mixgeneral is offline
I've produced a few projects that sounds similar. Not to be a copycat here:)) We would stack the vocal a few times, run each one through harmonizer/vocoder/auto Tune in full force. Each vocal processed separate with one not sellected on a plugin. So in essence you only hear one note at a time stacked 3-5 times. Eq the mids out of it and maybe add some brilliance with old SSL high shelf, I guess McDSP E6 has that characteristics too. Add a bit filtered Echo-boy to taste almost fading with original sound but creating length...
Effects on Vocals O.G General Discussion 3 02-10-2009 09:48 PM
Vocals - effects Ghostcage 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-15-2005 10:06 AM
Applying effects to vocals: Which effects are key? GapeOne 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-05-2003 09:36 AM
cher and her effects for her vocals zero8 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 06-13-2003 10:38 AM
Effects on vocals - please help India001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 06-13-2001 07:25 PM
