mixer output too hot for mbox : (
i'm just hoping someone can confirm if i'm on the right track here?
just came from a live show where i tried to record a stereo mix out of the board into my mbox 2.... though, i knew from the very beginning the levels were clipping almost constantly : ( first mistake - no time for sound check. the house engineer handed me 2 xlr cables 'heres the right, heres the left'... which i put into the mbox2's mic inputs. i THINK that the output of the board was too high for the mic inputs, even though the pre's were all the way down with pads on both input. so... i guess my question is .. how do i avoid this? would the solution be to use 1/4" trs as a line input? ..but what if it's too hot there, as well? are there different outputs of the board i should be looking at? |
Re: mixer output too hot for mbox : (
You have answered your own question really.....
Yes... Line level out of the console into line level in on your MBox2 (TRS inputs). Mic pres are expecting a very low voltage and you were giving it more than it could handle. Mic pre's are for microphones, they boost mic level up to line level. If the console delivers line level (with head room) and you plug this into your line inputs, there will be no clipping. hope this helps dogon |
The key to remember here is; XLR cables are used for both mic signals AND line signals in pro audio. You can avoid this next time by always carrying a pair of XLR-F to TRS cables so if you get handed the same as this time, you can pop in your adapter cables and be good to go. The XLR inputs on the Mbox are mic level only and the TRS inputs are suitable for line level.
you guys rock, thanks!
No output device selected in Studio Monitor Express, using Default Output (Mbox Pro). | Focuret | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-12-2014 07:33 AM |
Connecting 6 mics and sound output fom a Mixer to a DIGI002 | cesemj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-10-2007 11:09 AM |
002 (Mixer) output distortion on one channel issue | foxlemieux | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-04-2006 06:56 PM |
No output button on mixer in pro tools | arti | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-10-2005 10:06 PM |
Patching each output of Digi001 into individual Mono inputs on mixer | Rayman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-20-2003 04:28 AM |
