Re: ProTools 12.3.1 or 12.4 That is the ?
Jaun
Do you know of a blog or Vlog that explains what your talking about step by step for Mac ? Thanks |
Thanks Juan,
do you know of a video or a blog that explains what you're talking about in detail step-by-step days? Thank you |
Google, using boot camp on Mac....and basically have another hard drive backed up (i.e. Cloned) ready to put back in your system should things go sideways
Thanks Again Got it -
Btw Yosemite 10.10.3 with ProTools 12.4 so far so good :) Thanks Again everyone ✌🏽️ |
Related question -- PT 12.4 on Yosemite is not recognizing 3rd party plugins:
I just upgraded OS X to Yosemite 10.10.5, and installed PT 12.4 (from previous 11.3.1). The new Pro Tools 12.4 does not find/recognize my 3rd party plugins - including WAVES, Melodyne, and others. All the plugs are 64 bit AAX, and worked just fine with PT 11.3.1. I figure I've just missed something obvious, but having not found an answer yet, does anyone have suggestions on how to set PT 12.4 so it can see 3rd party plugs? |
Trash preferences and databases and see if that helps as PT will read in all plugins again.
--------- Good idea. As it turned out, I backtracked through the steps I'd taken to manually uninstall PT 11.3.1 before installing PT 12.4, and discovered I had moved my 3rd party plugins. I put the plugins back where they belong in Macintosh HD>Library>Application Support>Avid>Audio>Plug-ins, and that fixed the problem (as usual, self created problem). Thanks for the trash preferences and databases option - I've made note of it, as it'll likely be useful down the road. |
changing from protools 8 audio only to protools 8 with video support | djkaz | macOS | 5 | 09-04-2013 04:00 PM |
I have ProTools 8, But Avid is only giving me ProTools 7.x Authorization Codes | jpsaylor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-14-2012 08:34 PM |
Protools 8 LE/ Error 5000 / Protools freezes constantly HELP! | G ray | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-12-2011 07:09 PM |
Sending protools projects to other protools users online | kdtufan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-24-2008 07:18 PM |
setting record levels into ProTools with the intent of mixing in ProTools | Felix | Tips & Tricks | 507 | 02-05-2002 10:17 PM |
