Old 04-06-2018, 12:06 AM
Micphilp Micphilp is offline
Default Pro Tools not showing up in ‘External Devices’ on S3
I’ve been having ongoing issues connecting pro tools to my S3. Sometimes it works perfectly and other times I cannot for the life of me get them to talk.
I’ve been through the set up tab on pro tools- it’s set to E3 engine, TCP/UDP 29292, defaulted the inputs and outputs in I/O.
On the S3, if I go into Options-Interaction- Ethernet Control the venue link is enabled and status says connected to S3L protools but it won’t show up in External Devices.
I had everything set up exactly the same way two days ago and it was working perfectly. Any suggestions (other than turning it off and on again) would be much appreciated!
Old 04-06-2018, 07:26 PM
EddieJones's Avatar
Default Re: Pro Tools not showing up in ‘External Devices’ on S3
Hi, this is a forum for the S3, not S3L so unfortunately I can't help you. try this forum http://duc.avid.com/forumdisplay.php?f=25
Old 04-06-2018, 09:35 PM
Thanks Eddie,
I’m absolutely sleep deprived haha
Old 04-06-2018, 11:56 PM
Karel Noon Karel Noon is offline
How is it connected and what software do you have on the E3 and your Mac?
I had the same issue and it was just a bad cable.... the thunderbolt to Ethernet Adapter was broken.
Old 04-07-2018, 03:26 AM
RSendra RSendra is offline
And what OS & PT version are y using. All time with same Cat5e+? Did you switch off Wifi? Did you check at PT/Hardware/Devices/Venue the correct interface and, then, check the ENGINE?
UAD 9.3.0 with Pro Tools 12.8 - Not Showing In Playback Devices [solved] ShiftStudios Pro Tools 12 3 09-29-2017 10:09 AM
Pro Tools sudden "missing iLok" message when connected external USB devices. mgoorevich macOS 5 01-04-2012 02:13 PM
Problems with external MIDI devices and Pro Tools 8 Lac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-08-2011 09:44 AM
IAC driver in midi devices but not showing on PT8 crizdee Pro Tools TDM Systems (Mac) 1 03-05-2009 02:36 PM
Mbox 2 /PT LE 7 not showing up in audio devices tkrinor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-01-2006 09:50 PM
