Old 07-03-2006, 12:47 PM
c-post c-post is offline
Default how to slip audio inside a region??
Here is an ancient question that has been on my mind with regard to protools for 6 years. The solution/command is probably quite simple.
Say you have a trimmed region of audio in a given session. Now just imagine I want this region to be fixed and not to move positionally. However, I want to grab the audio inside the region (i.e. waveform) with my grabber and slide it forward, or back. The region does not move, but the audio inside it does (thus effectively trimming from the source audio). Pretty straightforward. How does one do this kind of command??
thanks
c-post
"TISH! You spoke PROTOOLS! Speak some more protools, Tish... disk allocation, degree of thinning, timeline insertion...ANYTHING!"
Old 07-03-2006, 12:52 PM
JKD99 JKD99 is offline
Default Re: how to slip audio inside a region??
I know!I know!I know!I know!I know!
Highlight the region, then Control + "+" or "-" nudges the audio within the region forward or back according to the Nudge value
Joe Milner
Puget Sound, Inc.
Los Angeles
IMDB
Puget Sound on Facebook
Old 07-03-2006, 01:04 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Me too...me too....I have another!!!
ctrl/opt/+ or - changes the nudge value. So you can move it, then lower the nudge value to do fine adjustments!!!!
I use the above daily.
IMDB
Old 07-03-2006, 01:28 PM
good one, never knew THAT was possible, thanks!
Joe Milner
Puget Sound, Inc.
Los Angeles
IMDB
Old 07-03-2006, 01:33 PM
Y'know, I always see you guys up on the boards helping poor, hapless souls like me, and I want to thank you for it.
By the way, I can't quite decipher DIAFXMX's nudge value shortcut. When I try it, it changes the grid value, not the nudge value. Also a footnote, the macros only work -/+ with the numeric keypad, not the alpha area.
-c-post
Old 07-03-2006, 02:14 PM
Sorry I do these without thinking, so I have to go back to see its
option/Apple with the + or - to change nudge value.
option + or - opens the front of the region by the amount and
apple + or - opens the back of the region by the amount
ctl/option moves the region internally only if there are handles available.
Yes the numeric pad is required.
IMDB
Old 07-04-2015, 05:12 PM
shayneallen shayneallen is offline
Old thread I know, but is it truly not possible to achieve this without a numeric keypad? I do a ton of editing on my laptop, and really hate that I can't achieve this function with just the laptop. I even bought a Bluetooth keypad, but that doesn't work either.
Old 07-14-2015, 11:51 AM
Testing, one...two...? :)
Old 07-14-2015, 07:35 PM
bashville bashville is offline
yeah sorry you need a full external keyboard with both the main qwerty board and numeric on the same device. It won't combine the modifier key from the laptop keyboard with the number from an external keypad. Been there with trying to do hotel room work on my laptop.
HD Studio, PT2022.6, UA Apollo x6, 2018 MacBook Pro, 32 Gig, Big Sur
Old 07-19-2015, 12:36 PM
Thanks for the reply. Ugh...I wish there were a workaround. I can't really mix on the road, or record, but I do a ton of editing. I hate the loss of that move though...one of my most often used edits.....
ControllerMate to slip audio within region BigBangPost Post - Surround - Video 0 10-11-2013 08:17 AM
Old region popping up when editing in slip mode Rick S Pro Tools TDM Systems (Mac) 0 01-31-2010 11:25 AM
Automation follows edit doesn't include region slip? Starcrash Post - Surround - Video 9 05-22-2008 01:27 AM
MOVING REGION IN SLIP MODE JAMES64 Pro Tools TDM Systems (Mac) 4 10-15-2007 02:24 PM
SLide audio inside audio region JuanM Tips & Tricks 2 03-22-2007 07:19 PM
