Some plugins don\'t appear in drop down menu.
This is a really strange issue. I'm running PT 7.1.1 on a macbook pro 1.83 Ghz, everything works great *except* some of my plugs don't show up in my sessions. All the stock plugs are there, as well as amplitube LE, T-racks eq, but my factory bundle plugins aren't there, or any other plugs I have downloaded from nomad factory, Roger Nichols digital, wrapped vst plugins via fxpansion, nothing. When starting PT I can see the plugins being authorized on the startup screen, my ilok is fine, the plugins are in the plugins folder, I've reinstalled PT 7.1.1, updated my OS, reinstalled the plugins, and I still don't see them. Has anyone else had this problem?
Re: Some plugins don\'t appear in drop down menu.
Roger Nichols Inspector "free" is a stereo plug in only and will only show up on a stero track. I can't speak for the others. But you might want to check that out.
Jason
Leo 10.5.7 PTLE 7.4.2, 002r, Micro iMac G5 2.33ghz Core Duo Intel OWC External FW HDD http://www.soundclick.com/jasonsheroan |
I have another post on here from earlier today with a similar problem. I can't get Reason to show up on insert. Suscks because my music is almost all composed on Reason, recorded on PT, and then live instruments and vox are added on top.
Also, check out this thread you can find on the main page ( click here It seems there is a problem with Intel based macs, but it sounds like you may not have an intel based mac. I really hope I can solve this problem ASAP.
Mac Mini 1.5GHz Intel Core Solo, 512 RAM, Mbox, PT 7.1, Oxygen 8. Dell Inspiron 9300 1.0 RAM, Mbox PT 7.0, external firewire drive, Oxygen 8. |
no options on the insert drop down menu | sterndrup | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 08-12-2022 03:13 PM |
Plug-In Will Only Show On Drop Down Menu | DJLilSteve | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-04-2010 08:44 AM |
Favourites in PT Drop Menu | ThisIsSick | Tips & Tricks | 1 | 09-26-2009 05:12 AM |
Drop down rates in RTAS menu???? | fantom27 | Pro Tools TDM Systems (Mac) | 4 | 03-20-2007 02:26 AM |
"Help" drop-down menu 7.3.1cs1 greyed out in XP | idylldon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-01-2007 05:29 PM |
