Old 12-21-2019, 11:27 AM
tkuhn89 tkuhn89 is offline
Default Cloud Uploads fail since upgrade to 2019.12/Catalina
As you all may know Avid issued their first version of PT that supports Catalina. I mistakenly did the upgrade as the email sent out by avid suggested that majority of the features should be working with Catalina - unfortunately, since doing the update - every time I try to upload tracks/audio to my cloud sessions - they fail to upload.
I have tried looking in the OS security settings to see if there is something blocking the connection - but that proved no results. I've tried all of the following with no luck fixing the issue:
uninstalled/reinstalled Pro Tools and the Cloud Client Services
trashed preferences
created a new user on the computer
tried wi-fi vs ethernet
I opened support ticket and they haven't provided much help. I'm wondering if there are any other users out there that have experience this issue and if they have any other suggestions. If I don't find a resolution soon I'm considering doing a fresh install of Mojave and reverting back to 2019.10. But I would love to avoid that.
Old 12-21-2019, 11:33 AM
Default Re: Cloud Uploads fail since upgrade to 2019.12/Catalina
Hi, welcome to the community.
Anyone else see this?
Old 12-29-2019, 11:29 AM
hakofred hakofred is offline
Exactly the same problem here. Have tried everything that you describes and still no solution. It seemes that all contact is blocked or not available.
When i am invited to a project, everything goes fine until the download of files starts. The Task Manager shows "failed" on all files.
Imac 21,5 late 2012, (upgraded 2018), i7 quad core 3,1 ghz 16 gb ram. Samsung Evo 850 SSD 1tb. Catalina 10.15.3, PT 2021.12, Waves Diamond ++. Native instruments komplete ultimate. Arturia Matrix 12v2. Mini V v3, Prophet v3, Air , Hammond B3x
etc...
Old 12-30-2019, 09:19 AM
So no one else experience this big problem? I find protools useless until this problem is solved.
etc...
Old 12-30-2019, 09:45 AM
jeffro's Avatar
jeffro jeffro is offline
I'll take a look for your support case, but in the meantime please see pg12 in the Mac Read Me for info on changing Full Disk Access from its default settings. The Read Me's are linked from the Pro Tools 2019.12 Release Info and this topic was added to its Tech Alerts section.
linkedin
Old 12-30-2019, 10:14 AM
Awesome Jeffro! Thank you, problem solved! After cheking this two files everything works fine
This shows how important it is to read the release documents properly before installing, me included!
etc...
Old 08-19-2020, 04:52 PM
seba.aracena seba.aracena is offline
How can I fix the same issue in High Sierra?
Sebastián Aracena
Producer & Guitarist
Latin GRAMMY® Winning Musician
Old 08-19-2020, 05:12 PM
jeffro's Avatar
Not the same issue if you are running High Sierra since this started with a change in Catalina. You also have similar posts across 4 threads, and your sig shows v12.7 but this is the 2019 forum. Help Us Help You
linkedin
Pro Tools 2019 + Catalina legasafe macOS 134 06-24-2020 11:37 AM
Protools 2019.12 and Catalina 10.15.2 combo jeam25 macOS 20 02-10-2020 12:03 PM
Pro Tools 2019.12 Catalina Support auratone Pro Tools 2019 27 12-19-2019 04:58 AM
Collaborative Cloud Issues - uploads fail cdengler Pro Tools 2019 9 09-25-2019 06:36 AM
