#81
Re: Pro Tools 10 on Windows 8??
Like others... I was having this issue on Win8.
Following the instructions with installing with capability mode (win7) and now PT10 works fine now. Thanks! |
#82
I followed all the steps for this and have Pro Tools 10.3.2 installed with the drivers but after loading, it freezes at "DAE Loaded" and a pop says "Unable to locate hardware" but the ilok is plugged in and so is my USB interface (Mbox 3). Can someone help me out?
#83
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
#84
My point is, the sentence that I quoted should read: "Pro Tools is NOT updated to run on Windows 8", not the other way around. Writing it the other way around almost makes it seem that Windows 8 is too inferior to run Pro Tools. I'm not "windows fan-boy" or anything, but the hierarchy of software for computer control dictates that applications are adjusted to work under the rules of the Operating System. It's up to Avid to update, not Microsoft, which is what a lot of people around here seem to be implying... Maybe I'm wrong. Jesus, if Microsoft wrote Windows to better suit Pro Tools, we'd still be back in the 1990's with 32-bit software
www.anvilaudio.co.uk - PC Users: Buy Skootch, you won't regret it. PC: Windows 7 64-Bit, ASRock Extreme 4 x79 Mobo, Intel Core i7-3820K @3.6Ghz, Kingston HyperX 16GB Ram, OCZ Vertex 3 64GB SSD, WD Caviar Green 2TB HDD, GeForce 560Ti GPU, SIIG TI Firewire Card, PT Keyboard. O/B: Focusrite Liquid Saffire 56, Focusrite Liquid Mix 32, Alesis D4 Drum Module, Alesis MIDIVerb4, M-Audio Axiom 49 v2, M-Audio BX8a's, Audix DP7 |
#85
My point is that you misunderstand the term "qualified" as used in a corporate professional studio environment. Over the past two decades most of my Pro Tools systems have in fact never been "qualified" and they've worked just fine.
You can be sure Avid is working on making Pro Tools 10 both install and run seamlessly on windoze 8 as soon as possible. "Qualification" will probably come much later if the past means anything.
Bob's room 615 562-4346 Interview Artists are the gatekeepers of truth! - Paul Robeson |
#86
Then writing code for PT 11 Porting all the VI's to a AAX Maybe one day looking at some compatibility for SSD on the recording drive Busy as bees over there man I tell you
#87
I think SSD is now qualified.
HD and CPTK will record on a USB key or over Wi-Fi!
#88
I got past the memory error by reinstalling the latest driver package from Avid 9.02.XX (cant remember exact version) and got a new error no-one has mentioned. The error reads:
"The software requires installation of device driver TPkd and a reboot before running. Please reboot or reinstall the software." Then after clicking ok I get: "Unable to locate hardware. Make sure hardware is connected and . . " If I then re-install the ilok drivers which is the source of TPkd I'm right back at the diskcache error. It is really screwed up when the idiot security device is what stands between me and the successful launch of a very expensive and critical program. Last edited by ziphler; 12-08-2012 at 10:54 PM. Reason: add specs Host Name : Homeboy |
#89
OK PROBLEM SOLVED. I just had to learn how to follow these threads better. Running the setup in the protools installer folder in win 7 compatability worked. I'm embarrassed that I didn't try this a week ago.
I too have wanted to make this work with windows 8 before its time and have always accepted that I get what I ask for so shouldn't haved griped about the ilok driver holding me up in this circumstance. HOWEVER I reserve the right to bitch about the required existence of the ilok in the 1st place. The very presence of the 003 hardware should proof enough for protools. Sure it might be stolen but that would be the exception not the rule and anyone who steals a 003 and knows what to do with it will steal the ilok too. As far as I'm concerned the hero here is Microsoft (sorry apple freaks, I've been a Microsoft whore since 1987) who, since win 2000, have been committed to backwards compatibility (all the way back to early dos programs) and have refined that ability ever since. All the problems with protools and win 8 are solved by hiding win 8 from protools and the OS does have that ability more comprehensively than ever. |
#90
A lot of these problems could be solved if u use the right msi installer forom the beging in compat mode for win 7
Pro Tools 11 on Windows 7 or Windows 8? | ianbee | Windows | 6 | 08-15-2013 04:04 PM |
Upgrade From Pro Tools LE (Windows XP) to 10 (Windows 7) | miek07 | Windows | 3 | 07-26-2012 07:49 PM |
Updating Pro Tools and Mbox from Windows XP to Windows 7 | ryanjantz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-29-2011 04:22 PM |
Opening a pro-tools HD session on a windows Pro-Tools LE M-powered system | rhodamorgan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-21-2010 05:31 PM |
Pro Tools LE vs. Pro Tools M-Audio - Any difference? Windows 7 | gbross | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-21-2009 08:24 PM |
