AVID and PT sync question?
This is probably a fairly basic question?
Is it common to slave Pro Tools via SMPTE Timecode to AVID systems cause PT has better audio editing facilities? (Or has AVID got comparable audio editing capabilities) Also how would this be done, I think I am correct in thinking you would need the Sync Hardware from a TDM system. Thanks for your time.
SafeandSound Mastering |
Re: AVID and PT sync question?
The AVID does not output LTC. It can only control RS-422 decks.
Frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
to AVID systems< No, this is almost never done and I have never done it personally. A common workflow is: picture edited on the Avid, picture is then output to tape or Quicktime file, picture is imported into Pro Tools, sound is edited, mixed and final mix tracks are brought back in to the Avid for final finishing and layback. Since you bring the sound files right into the Avid, there is really no need to lock Pro Tools to an Avid system. It wouldn't be cost effective anyway to use an Avid to play picture for Pro Tools. Avids make their money editing and finishing the picture, not as a tape deck.
Mark Ettel C.A.S. |
You can output LTC by placing SMPTE code on an audio track in the Avid.
It's not an efficient solution but it might be OK for a one time adventure in the Post realm.
Thanks there. I am new to Sound to Picture(not that you would have guessed) and have a lot to learn as yet
I appreciate what a massive field of work this is but thank you people very much for spending time responding. My previous understanding was that For example that a Voice over could be inserted over the video and incidental music played in etc on an AVID system. And then if complex Audio edits/sweetening needed to be performed then Pro Tools could be slaved via TC but it seems that is not the way its done. May be my question should have been: What Audio editing capabilities does AVID have? and do they come close to Pro Tools? I think I may be getting a bit mixed up with what Audio Post Production actual definition is here. Is it strictly syncing to a Pro Video master tape once all incidental and location sound is on the tape for example adding EQ, dynamic control, denoising, foley effects, Addition of any music that needs to be in place over the video? Thanks
The Avid interface isn't designed with audio as the main objective, that doesn't rule it impossible. It takes more time to do audio work on an Avid.
For example, an Avid can't edit audio (video) in smaller steps than a videoframe (40 msec where I reside). Theres a lot to gain by doing the audio in ProTools. Speed, functions, and quality of the result is easier to achieve with a dedicated audio software. |
Avid has (for video not film) 30 "chunks" of audio every second. it is "frame" accurate as there are 30 Frames per second of time. ProTools gives you 48000 "chunks" in that same second of time, so it is "sample" accurate. giving you acces to each of the 48000 samples that make up the audio. You can edit alot closer in protools than in an Avid system. It IS neccessary to use ProTools to clean up audio for video/picture.
or A screwdriver can be used to drive a nail, but a hammer is the right tool for the job.
Ray Trujillo Freelance Audio Engineer |
Thanks for your time all!
confused? you will be!
adam taylor video editor/dubbing editor/sound design/motion graphics/compositor United Kingdom |
AVID Sync HD won't generate 23.976 LTC | jim33 | Pro Tools TDM Systems (Mac) | 1 | 01-20-2012 10:20 AM |
Avid Standard Support - question for Avid | Bo Walker | Pro Tools 10 | 9 | 12-13-2011 03:08 AM |
sync to Avid Scratch | rafukyo | Pro Tools TDM Systems (Mac) | 1 | 02-11-2010 04:12 AM |
omf avid to pt: sync slippage | c-post | Post - Surround - Video | 6 | 02-16-2002 10:34 AM |
AVID / PT sync - Help | Iamrod | Pro Tools TDM Systems (Mac) | 3 | 05-17-2001 01:33 PM |
