Old 09-26-2003, 11:58 AM
Detlef Brockmann Detlef Brockmann is offline
Default I want ProTools to send SMPTE
Hallo,
what device do I need so that my ProTools Mix+ (ProTools 5.1.3) running on a PowerMac 9600 sends out SMPTE? Will Digidesign's SMPTE SLave Driver (SSD) do the job?
Detlef.
Old 09-26-2003, 12:22 PM
woodywho woodywho is offline
Default Re: I want ProTools to send SMPTE
trusty ole studio 4
Have you seen my 2 inch reel??
HitBound Studios
Old 09-26-2003, 12:37 PM
selig selig is offline
Depending on what you're trying to do, there is another way to send SMPTE. I call it the 'brute force' method. Simple record a SMPTE audio file at the sample and bit rate your session is at, and at the SMPTE frame rate you require (preferably from the SMPTE device you will use to read the code with) and import it into the session you are working with. Assign it to it's own output and patch that output to the time code reader. It's like a time code track on an analog multitrack machine, without the guard track! Depending on your setup, your word clock will still need to be configured and routed appropiatly.
Old 09-26-2003, 01:18 PM
thanx selig. That is the way I used to do it but I want to save one track. Maybe I wasn't clear enough, I want ProTools to translate it's time into SMPTE so I can synchronise my console automation to it. Will the SSD do this translation ?
Detlef.
Old 09-26-2003, 03:28 PM
Tweakhead Tweakhead is offline
Detlef.
No. You need a USD or SYNC IO. In the session setup window check the 'generate' box, put Pro Tools transport online. Hit play. Voila, you are generating code.
Old 09-27-2003, 03:09 AM
Wolfgang Eller Wolfgang Eller is offline
Or use a Rosendahl MTC to SMPTE converter.
That´s way cheaper.
Cheers Wolfgang
www.srs-mastering.de
Mac Pro 6.1-8core, OS 12.6, PT2023, HDX2, Sonnet Echo Express III-R, Madi Interface.
Old 09-27-2003, 04:05 AM
kurt's Avatar
kurt kurt is offline
SSD vill for some reasons not, but (now very cheap) MTP AV vill do it flavesly. Just mark (in Sesion set up) MTC to MidiTimePiece-Modem & Set MTP AV to read MTC at right Fr.Rate & Sampling fr. If you clock MTP AV externally set it to read MTC/Video. Very stable.
MBP early 2011. Apple MacPro 5.1 12Core ”Westmere”. DeckLink HD Extreme 3D+. OS X10.10.5
PTN|10-11. PTN|HD|10-11-12. 16 x 16 HD I/O - 16 x 16 192 I/O Lots of gear.
http://www.mmvstudios.com
Old 09-28-2003, 02:55 AM
GS-DK GS-DK is offline
Hi
I don't understand this. I am using my SSD to send out code to my Akai DR16 and Yamaha 02R - absolutely no problem at all. I am using a Mac DP867 running system 9.2.2 - and PT 5.1.3.
GS
Old 09-28-2003, 03:38 AM
kurt's Avatar
For some reasons vill my trusty SSD only send SMPTE from PT|5.1.3 if I generate SMPTE. Not just plain follow PT as my MPT AV do.
I´m using SSD to read code from different Video decks & MTP AV to send code from PT to: AKAI DD8+/Tascam DA-88. = No repatching. Everything resolved to Rosendahl Nanosyncs.
002R, 6.9LE and DV Toolkit - how to SEND SMPTE TC danajae 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 07-22-2005 11:29 AM
Can a Unitor 8 send SMPTE to console ? (or vice versa) auxsend1 Pro Tools TDM Systems (Mac) 15 06-28-2003 01:37 AM
how to send time code/smpte beau 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-18-2000 05:49 PM
How to send SMPTE from my Digi001 Rig??? pnoise 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-18-2000 08:40 AM
How to send SMPTE from my Digi001 Rig??? pnoise 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-16-2000 09:01 AM
