Old 11-14-2012, 08:07 AM
jalber jalber is offline
Default Mbox 2 mini does not work properly on Win7 and PT8.0.5
I own a Mbox 2 mini and I recently update my PC to Win 7 64 bit. I use Pro Tools 8.0.5 on it.
I have experienced a distorted and intermittent sound when I try to listen to some recordings or even listening to windows sounds (using the Mbox as the main windows audio device).
I discard a problem with the Mbox because it works properly on my mac with mac ox leopard.
I supposed that the problem was the mbox audio driver. However, I have installed the latest version of the driver and did not get results.
I also read in the avid support site that mbox 2 was not fully compatible with earlier versions of PT8 running on win7 but this was supposedly solved from version 8.0.4 on.
I also have checked that PT8 is installed properly because I own a digidesign 003 rack and it works fine.
Does somebody know how to solve this issue??
Old 11-14-2012, 05:57 PM
secondtyme secondtyme is offline
Default Re: Mbox 2 mini does not work properly on Win7 and PT8.0.5
If no one else chimes in I'm gonna have to guess it's the drivers. Are you SURE you have the propper drivers for the Mbox2?
Old 11-18-2012, 08:14 AM
Problem solved!
I unistalled the drivers and reinstalled. The problem persisted. I tried other USB ports and found one that made it work.
Thank you for your help!
Mbox Mini not working properly, help please. merlinhimself 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-13-2012 07:45 PM
mbox 2 mini don't work properly in windows 7 64bit funkman733 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-24-2011 02:05 PM
PTLE 8.0.4 + mbox mini + Win7 seanor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-03-2011 03:10 PM
Installation problem - Win7 PT8 Mbox 2 Mini shtik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-01-2010 10:16 AM
recording on mbox dosn't work properly Kyle.R 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 10-06-2005 03:00 PM
