#131
Re: TDM support in Pro Tools 11 petition.
I understand where you're coming from with it I'm just not understanding the coding enough if it is possible or not. It could be a great asset if it was possible, and if they were able to make it stable. But at the same time, would they need the consent of the other manufacturers to be able to do it, I don't know if FXpansion had to go through hoops to do what they did with the VST RTAS, not too sure what the implication might be for Avid to do it themselves.
#132
And Obama won the debate -!!!!
#133
But anyhow none of this has anything to do with 32 or 64 bit memory addressing to/from the host memory and applciation. The cards will have separate glue logic for handling main memory addressing, and there may be some DMA support involved (and just to confuse things the '321 chips at least have internal DMA to on-chip or on-PCI/PCIe board memory (I dont' think the earlier Presto chips did but can't recall/find a data sheet)). But again this is all different memory than the main host memory I doubt that when these card designed back in the dark ages, even the PCIe revision, they were ever intended to work with a 64 bit address so quite possible that memory addressing to and/or from the card is capped at 32 bits (even if the PCIe bus supports 64 bit addressing). But who knows. Even if any problems with 32 bit memory addressing to/from the card was dealt with, the TDM plugins themselves run in-part as 32 bit code on the host side and so can't run in a 64 bit address space, and you would have to bring over lots of the legacy 32 bit TDM runtime support code. Ah I know... add a separate 32 bit processes to run the plugins in a compatibility mode, and since its there you might as well have that process talk to the HD card, but that its as limited as before because its all 32 bits. Now how do you graft this Frankenstein-monster together with the new 64 bit core of Pro Tools? Oh well somebody will work that out, after all its "just software" and anything is possible. But all that brain surgery, old rotting body parts and smoke and mirrors will add significant complexity and likely introduce lots of problems, and for what benefit? To run some legacy boards (that are getting very slow compared to HDX or to native CPU) that the user could run by just staying at Pro Tools 10. And the retention of that legacy code may now made things impossible like freeze tracks or faster than real time bounce that lots of people have been asking for but RTAS and/or TDM legacy plugin architectures apparently make difficult to implement. I might be wrong and maybe there is a technical absolute show stopper reason why this is not possible, but hand waving and saying something is possible in principle/theory with software like the OP has is not much of a claim, doing it and shipping a usable, stable, testable and supportable product in a reasonable time frame is a another whole story. Just take your Pro Tools 10 system, buy all the TDM plugins you'll ever want, don't upgrade anything and it will keep running your old HD cards until they or the computer breaks. Avid really should not be looking back worrying about this, and the good thing is there is no sign they are. Darryl |
#134
I Bought HDX with the promise of plugin support I have not been able to get the plugins I NEED to make a album the way I want to. |
#135
Sheesh, don't take this wrong caused it's not aimed specifically at you, but I wonder how most of you guys would have reacted when Avid came up with TDM and actually didn't have the transition phase that we are enjoying with PT10/HDX. Now, now, now, now, now, not tomorrow, now, spoon fed, we can't wait, waaah. This job requires load of patience (mostly to deal with the artists) so where is it with you guys? |
#136
I don't own a TDM system... I've got no stake in this.
From my point of view, I don't even see a reason to buy 10... let alone 11 that won't support anything but AAX. Be that as it may... I try not to let anyone string me along. But if I had actually bought into TDM, paid double price for plugins which will also be unusable in the new software... I'd feel like a sucker!
Protools 10.3.10/11.3.2/12.6 | Win 7 Ultimate 64 bit |
#137
TDM owners will be able to do everything the day after 11 comes out they are doing today. It's not obsolete if you can still do real work on it.
Digi003 came out 5 years ago, it's EOL in 11. The lifespan of an iphone is what, 36 hours or so. THe HDX folks are dealing with the same thing all early adopters face, the ecosystem isn't there yet and things might not develop the way you assumed they would. That's why they call it the bleeding edge. |
#138
Oh and I often do hour long sessions. The possibility of a non-realtime bounce is also something that could really help me.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier. |
#139
froyo |
#140
Been thinking about this some more. If you must have TDM and pro tools 11, sync two rigs. Your TDM system running what you need to there on pr10 and a pt11 system for AAX plugs and VI's. Best of both worlds.
VENUE Support Petition | DJ Insomaniac | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 11-08-2004 06:39 PM |
ReWire Support Petition! | andyo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 150 | 01-18-2003 12:33 AM |
VST instrument support petition. | tommydee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 10-22-2002 10:51 AM |
digi support for UAD-1 petition... | Rokhead | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-04-2002 03:19 PM |
- video support petition - | mjames08 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 23 | 12-18-2001 11:46 AM |
