Old 10-14-2003, 02:40 AM
tsd tsd is offline
Default powerbook & 002r storage question
just picked up a 867 15" powerbook and want some advice on external HDs. how well does protools run when the 002r is chained with a harddrive?(there is only 1 firewire port) has anyone had good results from harddrives on USB2? what do the peoples of the DUC recommend?
Old 10-14-2003, 02:57 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: powerbook & 002r storage question
good experiences.
connect firewire hard drive as a first device (straight to the powerbook's firewire port) and connect 002r to the hard drive's second firewire port as a last device in firewire chain. it will work the other way also, but it's safer to put hd first. if you turn off your 002r, then the hard drive will power off too.
anyway.. i have a 667mhz powerbook, a 160gb lacie hd, and a 002r. works every time.
Janne
Old 10-14-2003, 09:38 PM
tsd tsd is offline
if you dont mind me asking, what kind of track/plug count are you getting with that setup? also how diferent is the performance when running audio off the internal drive?
thanks mate
Old 10-17-2003, 12:56 AM
Scott Gibson Scott Gibson is offline
I've had darn-near-equal performance with USB 2.0 and FireWire400 working with my new 1.25 Powerbook.
I can't tell what is worse: Having the 002R and Hard disk daisy-chained on the same bus, or using USB 2.0.
I've decided that I'm going to return my USB2/FW400 Drive to CompUSA that I paid too much for, eat the 15% restocking fee , and get myself a FireWire800/400/USB2 Drive. That way, I'll know that I'll be getting the best performance possible.
Cheers,
Scott
002r & new powerbook 1.6 hi res davedanvers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-28-2005 11:27 AM
17" Powerbook with 002R drmbeat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-09-2005 01:57 PM
002r with a Powerbook 800? centerstage 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-05-2005 09:01 PM
12" Powerbook and 002R. How do you do it?? unobus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-06-2005 12:02 PM
who is using a 867 15" powerbook with 002r tsd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-04-2003 03:26 AM
