Old 03-01-2019, 10:44 AM
alhardy alhardy is offline
Default PT moves recorded audio early. HELP! PT2018
New apartment system with mackbookpro and focusrite 2i2 2ndgen
felt my timing was odd after recored so I did some tests.
playing to a drum audio track I recorded simultaneously:
1) my guitar on one track
2) my guitar + the drum playback via bus1-2 mixed on another track
The drums align perfectly between the DR track and the mix track
The guitar only track results about 382 samples (8ms)ahead of the mixed track
Tried ADC on and off
The system is PT2018.12 - Macbook pro 2011 El Capitan 8g Ram and SSD - Focusrite 2i2 interface. Guitar was plugged directly, no plugs. Buffer 64
Alberto Lombardi
PT 8 HD2 Accel PCI on win XP
3 192 blue
882|20
PT 2018.12 on mackbookpro 2011 focusrite 2i2 2nd
www.albertolombardi.com
facebook - instagram - youtube
Old 03-01-2019, 10:59 AM
BScout BScout is offline
Default Re: Recorded track gets moved ahead PT2018
I can see delay comp is off (there would be a little "Dly" in green under the counter). Turn it on.
When you track, the signal chain on that track isn't compensated but when you playback (not in record or input), it should be aligned.
Otherwise, reduce your audio hardware's buffer to the lowest possible. Sadly, that's not very good with the Focusrite 2i2. That is the delay that makes this happen (output buffer delay to your speakers before you can hear the backing track and then input delay of taking your mic/line-in signal and converting it to be in Pro Tools. So in essence, you end up with a delay of twice the buffer setting)
sorry, just saw you have tried ADC on and off. You'll just have to reduce your audio hardware's buffer.
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 03-01-2019, 11:09 AM
Thanks for the reply Bscout, buffer was low 64.
What I mean is what I hear while I'm tracking is not what I hear when listening to it played back.
In fact the timing on the mixed track (guit+drums) sounds right, the 2 tracks by themselves are off. How would you explain that?
Alberto Lombardi
3 192 blue
882|20
Old 03-01-2019, 11:35 AM
That sounds like a bad audio driver for the Focusrite that is misreporting it's buffer latency to Pro Tools. Unfortunately, the 2i2 has been plagued with these problems. Do you have another audio interface to try? I note you are on El Capitain (which was/is one of the worst operating systems for audio) -- can you upgrade to Sierra? And then make sure you reinstall the latest 2i2 drivers?
Old 03-01-2019, 12:05 PM
Thanks for helping out man.
No I only have my main HD system PT8 in the studio, but nothing to test beside the 2i2. The drivers aren't avail according to focusrite since the interface is class A compliant on Mac
I calculated 383 sample delay, at 44.1 it's almost 9ms, audible and I feel it damn.
I could move the track by hand
Alberto Lombardi
3 192 blue
882|20
Old 03-01-2019, 12:27 PM
I did a phase test, guitar cancels out if I move it ahead of 382 samples at 44.1
Alberto Lombardi
3 192 blue
882|20
Old 03-04-2019, 04:43 AM
bump
Alberto Lombardi
3 192 blue
882|20
Old 03-04-2019, 05:04 AM
Maybe lose El Crapitan (the worst OSX ever released)?
Jack
QAPLA!
Old 03-04-2019, 05:51 AM
Yeah, I'm always worried when upgrading OSX.
Might try.
Alberto Lombardi
3 192 blue
882|20
Old 03-04-2019, 10:57 AM
Might try.
Make a clone backup (you are already making backups of your working system right?) to an external drive. Then install whatever OSX you decide to go to on a clean system drive - do NOT install right over the existing OSX otherwise known as an in-situ install (even though that's the Apple Way). The install all programs anew; do NOT use Migration Assassin.
Jack
QAPLA!
Audio Recorded from MIDI track ahead of the beat/grid CalebB macOS 1 10-23-2012 12:03 AM
recorded midi is ahead by 1/32 note! PhilBuckle Pro Tools TDM Systems (Mac) 3 01-24-2009 10:29 PM
Recorded MIDI is ahead in playback BiggiT MIDI 7 06-06-2007 12:17 PM
Re: vocal track has moved ahead a few bars??? mikef585 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-09-2005 06:42 PM
